e-ManualTopSite mapHelp
Top » Basic Printer Operations » Canceling a Job
Canceling a Job
08X4-03L
You can cancel a print job using either of the following methods.
 Operations from the Computer
You can select jobs from the print queue and cancel them.
When the printer is connected to the computer using a LAN cable, you can cancel printing from the Remote UI.
 Canceling from the Printer Control Panel
You can press [  ] (Job Status/Cancel) and cancel the job.
You can cancel other user's jobs.
<If an error is occurring to a job>
Solve the problem using either of the following methods.
Outputting Data (Forced Output)
You can force the printer to output the print data.
Canceling the Process Currently Being Performed (Soft Reset)
You can cancel the process currently being performed.
<When canceling all the jobs>
You can cancel all the jobs using the following method.
Canceling All the Jobs (Hard Reset)
You can delete all the jobs or data which was already sent to the memory.
