Load custom size paper in the same manner as you load standard size paper.
For details on the paper that you can load in the paper drawer, see "Usable Paper."
Load paper in Drawer 2 or 3 (optional) in the same manner as you load paper in Drawer 1.
Before loading paper, see "Attention (Paper Drawer)."
Be sure to load paper in landscape orientation if all the following conditions are fulfilled.
You are using the UFR II printer driver.
[Drawer 1 Size], [Drawer 2 Size] and [Drawer 3 Size] are set to [Mixed Sizes].
Custom size paper whose long edges are 8.50 in. (215.9 mm) or less is loaded.
See "Paper Loading Orientation" and load the paper in the correct orientation.
Slide the paper guide at the rear center toward you.
If the paper guides are too loose or too tight, this may result in misfeeds or paper jams.
(A):
Paper larger than A5
(B):
Paper smaller than A5
Be sure that the paper stack does not exceed the load limit mark lines. If the paper stack exceeds the load limit mark lines, this may result in misfeeds.
