» Troubleshooting » A Message Appears in the Control Panel
If an error is occurring for some reason during printing, a message appears in the display of the control panel. Perform solutions according to the displayed message.
Service call message
It is an error state in which the printer cannot print.
Warning message
It is a warning state in which the printer can print, but some solution is required.
Depending on the message type, the message does not appear if [Show Warnings] is set to [Off].
Error message
Mark
Description
<Auto Error Skip>
For a message with this mark, perform the following procedure according to the situation.
When you want to skip an error (error skip) and continue to print
Press [  ] (Online) to skip the error. (Printing is continued.)
If print data is missing or is not printed properly, print again.
If [Auto Continue] is set to [On], you can skip the error automatically.
If you want to cancel a job
Perform a soft reset.
Solve the problem according to the displayed message (this item).
Press [ ] (Online) and print again.
If multiple warning states are occurring at the same time
Warning messages are displayed alternately.
If an error state and warning state are occurring at the same time
A warning message is not displayed.
Service Call Message
Warning Message
Error Message
Ennn-nnnn ("n" represents a number.)
<Cause> A problem is occurring inside the printer.
Solution
Solve the problem following the instructions in "If a Service Error or the Message <F9-nn PWR OFF>ON> Is Displayed."
E001-nnnn ("n" represents a number.)
<Cause> A problem is occurring with the fixing unit of the printer.
Solution
Follow the procedure in "If a Fixing Unit Error Is Displayed" in "The Message Indicator Is On", and then contact your local authorized Canon dealer.
E003-nnnn ("n" represents a number.)
Solution
E004-nnnn ("n" represents a number.)
Solution
1F Output tray is full.
<Cause> The output tray is filled to the limit.
Solution
Remove the paper in the output tray.
1H Re-insert the toner cartridge.
<Cause> There is a possibility that the toner cartridge is not installed properly.
Solution 1
Remove the toner cartridge, and then reinstall it properly.
Solution 2
If <1H Check toner connect.> appears and there is a problem with the print quality even after applying Solution 1, remove the toner cartridge, and then replace it with a new one.
80 Do not turn the main power OFF.
<Cause> A MEAP application is running.
Solution
Wait until the message disappears.
BT Clock error.
<Cause> The clock in this printer has a problem.
Solution
Though printing is possible as is, logs such as the job histories cannot be recorded correctly. Contact your local authorized Canon dealer.
EM E-Mail access error.
<Cause> The printer could not connect to the POP3 server because an error had occurred in its hard disk.
Solution
Clear the hard disk error on the POP3 server.
EM POP3 server error.
<Cause> The printer could not connect to the POP3/SMTP server when printing e-mails, or the settings for the POP3/SMTP server are not correct.
Solution
Check the error in detail using the Remote UI or Network Status Print.
IE An unknown error has occurred.
<Cause> An unknown IEEE802.1X authentication error has occurred.
Solution
Restart the printer. If the error message still appears after restarting this printer, contact your local authorized dealer.
IE Cannot analyze the certificate.
<Cause> During IEEE802.1X authentication, analysis of the certificate received from the authentication server failed.
Solution
Check the authentication server's certificate.
IE Change the password.
<Cause> The password used for IEEE802.1X authentication has expired.
Solution
Change the password registered in the authentication server, and reset the IEEE802.1X authentication password.
IE Check auth. settings
The printer and the authentication server use different IEEE802.1X authentication systems.
Solution
Change IEEE802.1X authentication systems.
IE No reply from the destination.
<Cause> During IEEE802.1X authentication, and error occurred while communicating with the authentication server.
Solution
Check to see if the cable is disconnected.
IE Set necessary authentication info.
<Cause> There is information missing from the IEEE802.1X authentication settings.
Solution
Check the IEEE802.1X settings, and reconfigure them.
IE Set the correct authentication info.
<Cause> An error was returned from the authentication server because the certificate used for IEEE802.1X authentication is not correct.
Solution 1
The certificate used for TLS authentication is not correct. Check the certificate, and reconfigure it.
Solution 2
If the printer's certificate is correct, check the authentication server's CA certificate.
IE The certificate has expired.
<Cause> During IEEE802.1X authentication, the certificate received from the authentication server was an expired certificate.
Solution 1
Solution 2
Check the printer's and the authentication server's time settings.
IE The certificate is incorrect.
<Cause> During IEEE802.1X authentication, an error occurred as a result of the verification by the CA certificate of the certificate received from the authentication server .
Solution 1
Solution 2
Install the CA certificate in the printer.
NW Competing IP add. found on the network.
<Cause> The IPv4 address set for the printer overlaps with another host on the network.
Solution
Change the printer's IPv4 address and restart.
An error occurred while receiving. <Auto Error Skip>
<Cause> The printer received any unanalyzable data while it is receiving a job, or it timed out.
Solution 1
Press [  ] (Online) to cancel printing, and then print again.
Solution 2
A problem may be occurring in the network you are using. Check the status of the network that you are using.
Cannot decode data. <Auto Error Skip>
<Cause> The printer could not analyze encrypted secured print data.
Solution
Perform a soft reset using the Reset menu, and then print again.
Cannot decode PDF data.
<Cause 1> An incorrect password was entered to print the PDF data.
Solution
Enter the correct password.
<Cause 2> The PDF data security settings do not permit printing.
Solution
Change the settings to permit printing.
Cannot feed paper.
<Cause> Paper of the size or type that cannot be fed from the multi-purpose tray or paper drawer is specified.
Solution 1
If a paper source is specified, press [  ] (Feeder Selection), and then set [Paper Source] to [Auto].
Solution 2
Press [  ] (Feeder Selection) to select another paper source.
Solution 3
Load paper appropriate for the paper source.
Solution 4
Specify the following items.
[Standard Paper Size]
[Default Paper Type]
Solution 5
Press [ ] (Online), and then print from the currently selected paper source. However, this may result in deterioration in print quality.
Cannot perform 2-Sided Printing. <Auto Error Skip>
<Cause> The printer received 2-sided printing data of paper sizes (including the orientation) or paper types unavailable for automatic 2-sided printing.
Solution 1
Press [ ] (Online) to continue printing. However, the data on each side is printed on two pages.
Solution 2
Perform the following procedure.
Change the setting to a paper size or type available for automatic 2-sided printing, and then print again.
Cannot print with the specified resolution. <Auto Error Skip>
<Cause> The printer cannot process the data because it is too complicated.
Solution 1
Press [  ] (Online) to continue printing. In this case, the printer prints with the image quality level being lowered.
Solution 2
Set [Gradation Level] to [High 1], and then print again.
Cannot print. Reg. Table is full. <Auto Error Skip>
<Cause> The total number of binders inside a single job exceeds 16, or the number of documents inside a single binder exceeds 16.
Solution 1
Press [  ] (Online) to continue printing. However, the data may not be printed properly.
Solution 2
Confirm the data to be printed, and then print again.
Cannot read PDF data.
<Cause> An error has occurred when the PDF data was read.
Solution
Print the PDF data in a format which this printer supports again.
Cannot receive PDF data. Set the receivable size. <Auto Error Skip>
<Cause> There is not sufficient free space to print the PDF file using the direct print function.
Solution 1
Press [  ] (Online) to cancel the job. Afterward, perform the following processes (decreasing the size of the PDF file), and then print again.
Optimizing the PDF file
Dividing the PDF file into multiple files
Solution 2
Send the file again using one of the following methods.
Insert the SD card into the slot and send the file again.
Send the file directly from the USB memory device.
Cannot start printing. <Auto Error Skip>
<Cause> The specified emulation does not exist.
Solution 1
Solution 2
Set a usable emulation using [Auto Mode Selection].
Cannot store. <Auto Error Skip>
<Cause 1> [SD Card] in the Control Menu options in the Setup menu is set to [Off].
Solution
Cancel printing by pressing [  ] (Online).
Set [SD Card] to [On] and print again.
<Cause 2> The number of the jobs exceeded the amount of jobs the printer can save (You can save up to 100 jobs in the SD card.)
Solution 1
The printer is ready to print by pressing [  ] (Online), ignoring the print data.
Solution 2
Delete unnecessary stored jobs.
<Cause 3> The number of the jobs exceeded the number of jobs you can save in the SD card.
Solution 1
Solution 2
<Cause 4> The specified box number is not correct.
Solution
Specify the correct box number.
Cannot verify. <Auto Error Skip>
<Cause 1> The department ID and password entered for your job did not match the department ID and password registered on the machine.
Solution
Print your job again by entering the correct department ID and password.
<Cause 2> Printing jobs with unknown IDs are disallowed.
Solution
Allow print jobs with unknown IDs from the Remote UI.
Check paper size.
<Cause 1> The size of the paper loaded in a paper source is different from the following settings.
Setting for [Output Size] in the [Page Setup] sheet in the printer driver
[MP Tray Paper Size], [Drawer 1 Size] or [Drawer 2 Size] in the [Select Feeder] menu
Solution
Specify the setting properly.
<Cause 2> When the following settings in the [Select Feeder] menu are set to [Mixed Sizes], custom size paper whose long edges are 8.50 in. (215.9 mm) or less is loaded in portrait orientation and printed (only when the UFR II printer driver is used).
[Drawer 1 Size]
[Drawer 2 Size]
Solution
Load the paper in landscape orientation, and then print again.
<Cause 3> When the UFR II printer driver was not used, custom size paper was loaded in landscape orientation to be printed.
Solution
Load the paper in portrait orientation, and then print again.
<Cause 4> [Check Paper Size] in the common [Setup] menu ([User Maintenance] options) is set to [On].
Solution
Set [Check Paper Size] to [Off], and then print again.
Close XXXX cover. (XXXX shows the cover name)
<Cause> A cover is open.
Solution
Close the cover firmly. If the printer is not online, press [  ] (Online).
IEEE802.1X error. Set the necessary auth. information.
Solution
Image browse data error.
<Cause> Data which this printer cannot process is included in TIFF data.
Solution
This printer cannot print the data. Press [ ] (Online) to cancel the job.
Image data error.
<Cause> Data which this printer cannot process is included in TIFF data or JPEG data.
Solution
Insert toner cartridge.
<Cause> The toner cartridge is not installed or installed improperly.
Solution
Install the toner cartridge properly.
Key management file is corrupt or deleted.
<Cause> The file related to key management is broken.
Solution
Select [Network] → [Remote UI Settings] → [SSL] using the control panel, then make sure that [SSL] is set to [Off].
Restart the printer, and then regenerate the key and certificate and specify the settings for SSL from the Remote UI.
Load paper.
<Cause> Paper of the size specified in the application is not loaded in the paper source (in all the paper sources when [Paper Source] is set to [Auto] and in the specified paper source when the setting is fixed).
Solution 1
Refill or load paper.
Solution 2
Press [  ] (Feeder Selection), and then select other paper source for the same paper size or larger paper size.
Not enough download memory. <Auto Error Skip>
<Cause> The memory for registering overlay forms and custom characters ran out and overflowed.
Solution 1
Press [  ] (Online) to continue printing. However, the overflowed data cannot be registered.
Solution 2
After the soft reset, either perform a hard reset or turn the printer back ON, increase memory capacity and print again. (All data in the memory will be erased.)
Not enough memory for PDF processing.
<Cause> There is not enough memory to process a PDF file.
Solution
Decrease the size of the PDF file or divide it into multiple files, and then print again.
The PDF data may be printed properly by opening it from an application and using the printer driver.
Not enough memory for XPS processing. <Auto Error Skip>
<Cause> There is not enough memory for XPS processing.
Solution 1
Press [  ] (Online), and continue printing. However, the data that generated the error will not be printed correctly.
Solution 2
If images such as Progressive JPEG are handled inside the XPS, convert them to TIFF or Baseline JPEG and then print.
Not enough spool memory. <Auto Error Skip>
<Cause> Because spool memory ran out, the printer cannot print.
Solution 1
Press [  ] (Online) to continue printing. However, the page with which an error is occurring is not printed.
Solution 2
Specify the paper size smaller, and then print again.
Solution 3
Set [Gradation Level] to [Standard], and then print again.
Solution 4
If [2-Sided Printing] is set to [On], specify [Off], and then print again.
Solution 5
Change the setting for [Halftones], and then print again.
Not enough system memory. <Auto Error Skip>
<Cause> The work memory required for the printer process ran out while the system was processing the data (mainly the graphics data and text data).
Solution 1
Press [  ] (Online) to continue printing. However, the data with which an error is occurring is not printed properly.
Solution 2
Not enough work memory. <Auto Error Skip>
<Cause> The work memory for each print mode cannot be secured.
Solution 1
When continuing printing by pressing [  ] (Online)
Be aware that the data of overlay or macro that is already registered may be deleted.
Solution 2
Output tray is full. Remove paper.
Solution
Paper is jammed.
<Cause> Paper is jammed inside the printer.
Solution
Remove the jammed paper and set the paper drawer and covers to the original position. If the printer is not online, press [  ] (Online).
If paper jams occur at multiple areas at the same time, the areas appear in the display by rotation.
If you removed the jammed paper without opening any cover, be sure to open and close the front cover once, and then press [  ] (Online).
PDF error.
<Cause> PDF data which this printer cannot process was sent.
Solution
PDF font error.
<Cause> PDF font which this printer cannot process was sent.
Solution
PDF print range error.
<Cause> The specified print range is incorrect.
Solution
Specify the print range correctly, and then print again.
Print data version error.
Solution 1
Solution 2
Print the data again from the printer driver for the printer.
55 SD Card error. <Auto Error Skip>
<Cause> An SD error has occurred.
Solution 1
If [  ] (Online) is pressed, settings that do not use the SD card are activated. However, you cannot print with functions that use the SD card.
Solution 2
Turn OFF the printer, and make sure that the SD card is inserted correctly.
Solution 3
Contact your local dealer for repairs.
56 SD Card error.
Solution 1
Turn the printer OFF, wait for 10 seconds or longer, and then turn it ON again.
Solution 2
Run SD card quick format or standard format.
Solution 3
Set below paper.
<Cause 1> The paper of the size specified in the application is not loaded in the paper drawer or multi-purpose tray, or the paper source for the different paper size is selected.
Solution 1
Load the paper of the size selected in the application (or the one specified by scaling factors).
Solution 2
Press [  ] (Online), and then print to the currently loaded paper forcibly. If you are using the multi-purpose tray, the setting for [MP Tray Paper Size] in the [Select Feeder] menu automatically changes to the paper size specified in the application.
<Cause 2> The paper size specified in the application software is different from the following setting.
Solution
<Cause 3> Improper paper source is selected.
Solution
Specify the setting for [Paper Source] in the [Select Feeder] menu properly.
When the message <Set below paper.> appears
If the front cover is opened, the message may disappear. However, be sure to follow the directions in the displayed message to change the paper.
Set cleaning paper and press the Online key. <Auto Error Skip>
<Cause> The printer is waiting to print cleaning paper.
Solution
Load Letter size or A4 paper in the multi-purpose tray, and then press [  ] (Online).
Syntax error.
<Cause> Invalid data is sent when printing using the UFR II printer driver.
Solution 1
Press [ ] (Online) to continue printing from the next data. However, the page with which an error is occurring and its subsequent pages are not printed.
Solution 2
XPS document data error. <Auto Error Skip>
<Cause 1> The XPS data or the data extracted from the XPS data are invalid.
Solution
Check to make sure that the data that was input is normal, restart it and print again.
<Cause 2> A high volume file was sent directly.
Solution 1
Press [  ] (Online) to cancel the job. Afterward, perform the following processes (decreasing the size of the XPS file), and then print again.
Optimizing the XPS file
Dividing the XPS file into multiple files
Solution 2
XPS font data error. <Auto Error Skip>
<Cause> Incorrect font data was received.
Solution
Check the output result for missing text, and correct the data.
XPS image data error. <Auto Error Skip>
<Cause> Incorrect image data was received.
Solution
Check the output result for missing images, and correct the data.
XPS page data error. <Auto Error Skip>
<Cause> Pages cannot be generated because the description is invalid.
Solution
Check the output result for missing pages, and correct the data.
XPS print range error. <Auto Error Skip>
<Cause> The specified print page range is invalid.
Solution
Check the page range, and print again.
XPS rendering error.
<Cause> An error has occurred in the XPS data rendering system.
Solution
Contact your local dealer.
XPS unsupported image error. <Auto Error Skip>
<Cause> Unsupported images such as HD Photo images are included in the XPS data.
Solution
Change the images in the XPS file to TIFF or JPEG format.
A4 nn Error ("nn" represents two-digit alphanumeric characters.)
<Cause> A problem is occurring and the printer does not operate properly.
Solution
Cycle the power of the printer. If the message appears even after cycling the power of the printer, note down the message in the display, and contact your local authorized Canon dealer.
A5 nn Error ("nn" represents two-digit alphanumeric characters.)
Solution
A7 nn ERROR ("nn" represents two-digit alphanumeric characters.)
Solution
D7 nn Error ("nn" represents two-digit alphanumeric characters.)
Solution
D8 nn Error ("nn" represents two-digit alphanumeric characters.)
Solution
D9 nn Error ("nn" represents two-digit alphanumeric characters.)
Solution
F9-nn PWR OFF>ON ("nn" represents two-digit alphanumeric characters.)
<Cause> A problem occurred while the printer was processing print data.
Solution
051R-0K1
