» Troubleshooting » Paper Jams » Clearing Paper Jams (Duplex Unit)
Referring to the procedure on the display, follow the steps below to remove jammed documents.
1
Press [  ].
2
Pull out the paper drawer.
3
Holding the green tab (A), open the duplex print transport guide.
4
Remove the paper by pulling it gently.
If the jammed paper cannot be removed easily, do not try to remove it forcefully but proceed to Step 5.
5
Holding the green tab, close the duplex print transport guide firmly.
Close it by pressing the both sides firmly.
6
Set the paper drawer in the printer.
7
Open the duplex unit cover.
8
If you cannot remove the paper easily, do not try to remove it forcefully but proceed to Step 9 and perform the clearing procedure for another area which is displayed in the message.
9
Close the duplex unit cover.
10
Open the front cover while pressing the open button.
11
Close the front cover.
The machine is ready to print.
Next, proceed to the clearing procedure for another area which is displayed in the message.
051R-0JW
