: Available
: Unavailable|
Paper Type
Setting for [Paper Type]*1
Paper Size
Paper Source
2-sided Printing*2
Multi-purpose Tray
Drawer 1
Drawer 2 (optional)
Plain paper*3 (16.0 to 23.9 lb Bond (60 to 90 g/m²))
[Plain] (Default)
[Plain L]*4
A4
B5
A5
A6
Legal
Letter
Executive
Statement
16K
Custom size paper
*5 |
*6 |
*6 |
Heavy paper (24.0 lb Bond to 55.5 lb Cover (91 to 150 g/m²))
[Heavy 1]
A4
*7 |
*7 |
*7 |
B5
*7 |
*7 |
A5
*7 |
*7 |
A6
*7 |
*7 |
Legal
*7 |
*7 |
*7 |
Letter
*7 |
*7 |
*7 |
Executive
*7 |
*7 |
Statement
16K
Custom size paper
*5 |
*6 *7 |
*6 *7 |
Heavy paper (55.6 lb Cover to 60.3 lb Cover (151 to 163 g/m²))
[Heavy 2]
A4
B5
A5
A6
Legal
Letter
Executive
Statement
16K
Custom size paper
*5 |
Transparency
[Transparency]
A4
Letter
Label
[Labels]
A4
B5
A5
A6
Legal
Letter
Executive
Statement
16K
Custom size paper
*5 |
Index Card
[Envelope]
Index Card
Envelope
[Envelope]
Envelope Monarch
Envelope No.10
Envelope DL
Envelope ISO-C5
Envelope ISO-B5
*1
The setting is located in the [Paper Source] sheet in the printer driver. If you print from DOS, UNIX, or other operating system, specify a paper type in [Standard Paper Size] in the control panel.
*2
2-sided printing supports paper with a weight of 16.0 lb Bond to 44.4 lb Cover (60 to 120 g/m²)
*3
Recycled paper can be also used.
*4
If the printed paper curls (the printed side curls outward) when printed with [Plain] selected, select [Plain L].
*5
You can load custom size paper that is 3.00 to 8.50 in. (76.2 to 215.9 mm) wide and 5.00 to 14.00 in. (127.0 to 355.6 mm) long. (If you are using the UFR II printer driver, you can load custom size paper that is 5.00 to 8.50 in. (127.0 to 215.9 mm) wide and 5.00 to 8.50 in. (127.0 to 215.9 mm) long in landscape orientation.)
*6
You can load custom size paper that is 4.13 to 8.50 in. (105.0 to 215.9 mm) wide and 5.83 to 14.00 in. (148.0 to 355.6 mm) long. (If you are using the UFR II printer driver, you can load custom size paper that is 5.83 to 8.50 in. (148.0 to 215.9 mm) wide and 5.83 to 8.50 in. (148.0 to 215.9 mm) long in landscape orientation.)
*7
You can load 24.0 lb Bond to 44.4 lb Cover (91 to 120 g/m²) heavy paper.
About print speed
The print speed may slow depending on the paper settings for the size, type, orientation, and number of copies.
When continuously printing paper whose length is 10.60 in. (269.3 mm) or less, the print speed may slow gradually.
When continuously printing paper whose width is 7.48 in. (189.9 mm) or less, the print speed may slow gradually.
Precautions for paper
Printable area
Envelope sizes
The envelope sizes are as follows.
Chlorine-free paper
Chlorine-free paper can be used with this printer.
