» Useful Printing Functions » Printing Files Directly from USB Memory Devices (USB Direct Print)
You can print data in USB memory device directly from the machine. Because it is possible to print without a computer, you can easily print data stored in a USB memory device at a location where the machine is installed. This makes immediate handling possible when printed documents are needed quickly.
You can print files directly from a USB memory device that is connected to the printer.
You can change the settings when printing.
You can change the default print settings and default file display sorting criteria. Settings that are often used can be conveniently set in advance as defaults.
Remove the USB memory device after printing has stopped. Use the correct method to remove the USB memory device.
In order to use USB memory devices, the following settings are necessary.
Set [USB] to [On]
(1)
Press [  ] (Settings), select [Interface] with [] and [], and then press [OK].
(2)
Select [Interface Selection] with [] and [], and then press [OK].
(3)
Select [USB] with [] and [], and then press [OK].
(4)
Select [On] with [] and [], and then press [OK].
Set [MEAP Driver] to [On]
(1)
Press (  ) [Settings], select [Interface] with [] and [], and then press [OK].
(2)
(3)
Select [USB Storage Device] with [] and [], and then press [OK].
(4)
Select [MEAP Driver] with [] and [], and then press [OK].
(5)
About USB memory support
The file format FAT32 is supported only.
USB memory drives cannot be read by this printer if:
these drives are partitioned
these drives contain encrypted data
051R-069
