» Managing the Printer » Specifying an ID for Each Department
Displaying or Changing the Departmental ID Management Settings
You can manage the number of [Printed Pages]* on a departmental basis by specifying IDs for each department and entering an ID when printing.
[Printed Pages] indicates the number of printed surfaces. If you perform 2-sided printing on a sheet of paper, the number of the printed surfaces is two.
Register more than one Department IDs before enabling Department ID Management, which will have no effect with no Department ID registered.
(1)
[Register New Department]
(Displayed only if you have logged on in Administrator Mode.)
Clicking this button displays the [Register New Department] page. You can specify the following settings.
[Department ID]
Enter the department ID using a number with up to seven digits.
[PIN]
Enter the password using a number with up to seven digits.
[Confirm]
Enter the number specified in [PIN].
(2)
[Dept. ID]
(Clickable only if you have logged on in Administrator Mode.)
Clicking the department ID displays the [Edit Department] page. You can specify the following settings.
[Department ID]
[PIN]
[Confirm]
[Clear Count]
(Not displayed depending on the settings.)
Click [Printed Pages] ([Total Print]) for this Department ID.
[Total Print]
Displays the number of printed surfaces.
(3)
[Settings...]
Clicking this button displays the [Department ID Management Settings] page. You can specify the following settings.
[Enable Department ID Management]
If the check box for this option is selected, you need to enter a department ID and password when printing. You also need to enter a department ID and password when you perform direct printing or manipulate boxes from the Remote UI. Jobs which failed to be authenticated are deleted.
[Accept Print Jobs With Unknown IDs]
If the check box for this option is selected, you can print jobs with unknown IDs. Jobs with unknown IDs indicate the following kinds of jobs.
Jobs printed by a printer driver which does not support the department ID management
Jobs directly printed using a method other than the Remote UI
(4)
[Printed Pages]
(5)
Delete the Selected Department
If you click [Delete] to the right of the Dept. ID to be deleted, the selected Dept. ID is deleted.
(6)
[Clear All Counts]
Clears [Total Print] of all the departments.
051R-0C9
