» Basic Printer Operations » Paper Loading and Output
This printer has the following paper sources and output trays.
Paper Source
(A): Multi-purpose tray
(B): Drawer 1
(C): Drawer 2 (optional)
Output Tray
(D): Output tray
Outputs paper with the printed side face-down.
(E): Sub-output tray
Outputs paper with the printed side face-up.
The sub-output tray is suitable to print transparencies, labels, or envelopes which tend to curl, since the printed paper is output flat.
How to Switch Output Trays
When switching to the sub-output tray
Open the output selection cover as shown in the figure.
When switching to the output tray
Close the output selection cover as shown in the figure.
Precautions for Output Trays
Observe to the following points when handling the output trays.
Before handling the output trays, see "Important Safety Instructions."
When performing 2-sided printing, close the output selection cover.
(When outputting paper to the sub-output tray, you cannot perform 2-sided printing.)
During 2-sided printing, do not touch the paper until it is completely output. The paper is first partially output after the front side is printed, and then it is fed again to be printed on the back side.
After paper is output to the sub-output tray, immediately remove each sheet.
When outputting long-size paper, such as Legal paper, to the output tray, open the auxiliary tray to prevent the paper from hanging out of the output tray.
Paper Capacity of the Paper Sources and Output Trays
: Unavailable
Paper Type
Paper Source
Output Tray
Multi-purpose tray
Drawer 1
Drawer 2
(optional)
Output tray*1
Sub-output tray
Plain paper (Ex. 19.9 lb Bond (75 g/m²))
Approx. 50 sheets
Approx. 250 sheets*2
Approx. 500 sheets*2
Approx. 150 sheets
1 sheet
Heavy paper (Ex. 44.4 lb Cover (120 g/m²))
Approx. 40 sheets
Approx. 200 sheets*2
Approx. 400 sheets*2
Approx. 20 sheets
1 sheet
Heavy paper (Ex. 60.3 lb Cover (163 g/m²))
Approx. 25 sheets
Approx. 20 sheets
1 sheet
Transparency
Approx. 15 sheets
1 sheet
1 sheet
Label
Approx. 20 sheets
Approx. 10 sheets
1 sheet
Index Card
Approx. 15 sheets
Approx. 10 sheets
1 sheet
Envelope
Approx. 5 sheets
Approx. 10 sheets
1 sheet
*1
Actual paper capacity varies depending on the installation environment and paper type to be used.
*2
If the paper size is smaller than A5 or Statement, the paper capacity is as follows.
Paper Type
Drawer 1
Drawer 2 (optional)
Approx. 150 sheets
Approx. 400 sheets
Approx. 100 sheets
Approx. 300 sheets
051R-035
