» Managing the Printer » Setting Items » [Select Feeder] Menu
Table description
Bold values in the table indicate the default settings.
The setting items or setting values with "*" may not be displayed depending on the availability of the optional accessories and other settings.
About the icon
The settings for the printer driver are prioritized for this item.
Setting Item
Setting Value
Setting
[Paper Source]
[Auto], [Drawer 1], [Drawer 2]*, [Multi-Purpose Tray]
Selects the paper drawer or tray from which the printer feeds paper. After a paper source is selected, the corresponding Paper Source indicator comes on.
[MP Tray Paper Size]
[A6], [A5], [B5], [A4], [LTR], [LGL], [EXEC], [Mixed Sizes], [Custom Size], [Custom Size R], [Env. ISO-C5], [Env. Monarch], [Env. No.10], [Env. DL], [Env. ISO-B5], [Index Card], [STMT], [16K]
Specifies the size of the paper loaded in the multi-purpose tray.
[MP Tray Priority]
[Off], [On]
Specifies whether the printer should detect the paper source in order starting with the multi-purpose tray when [Paper Source] is set to [Auto].
[Drawer 1 Size]/[Drawer 2 Size]*
[A6], [A5], [B5], [A4], [LTR], [LGL], [EXEC], [Mixed Sizes], [Custom Size], [Custom Size R], [16K]
Specifies the size of the paper loaded in the paper drawer.
[Standard Paper Size]
[A6], [A5], [B5], [A4], [LTR], [LGL], [EXEC], [Env. ISO-C5], [Env. Monarch], [Env. No.10], [Env. DL], [Env. ISO-B5], [Index Card], [STMT], [16K]
If you cannot specify the paper size or if you print from DOS, UNIX, or other operating system, specify the paper size in this item.
[Diff. Paper Tray]
[Off], [On]
Specifies whether the printer should feed paper from the multi-purpose tray when paper of the size for the received data is not loaded in the paper drawer.
[Auto Selection]
[Multi-Purpose Tray]: [Off], [On]
[Drawer 1]: [Off], [On]
[Drawer 2]*: [Off], [On]
Specifies the paper source to be automatically selected when [Paper Source] is set to [Auto] in "[Select Feeder] Menu."
If [On] is specified, the printer selects the paper source as the one to be automatically selected.
[Default Paper Type]
[Plain], [Plain L], [Heavy 1], [Heavy 2], [Transparency], [Envelope], [Labels]
Specifies whether the printer should print on one side or both sides of the paper.
[2-Sided Printing]
[Off], [On]
051R-0C0
