» Basic Printer Operations » Paper Loading and Output » Configuring the Printer Driver and Printing
After loading paper in a paper source, configure the printer driver to print using the following procedure.
This section describes the basic procedure for printing from an application, taking Adobe Reader as an example.
The printing procedure may differ depending on the application you are using.
1
Load paper in the paper drawer or multi-purpose tray.
2
Open the PDF file to be printed using Adobe Reader.
3
Select [Print] from the [File] menu.
4
Configure the printing preferences.
(1)
Select this printer.
You can change the printer name in the printer folder ( "Basic Operations/Various Information for Windows").
(2)
5
Click [Properties].
6
Specify the settings for [Page Size] and [Output Size].
(1)
Display the [Page Setup] sheet.
(2)
Select the page size of the document created by an application.
(3)
Select if the size of the paper to be printed is different from that of the data.
If the [Page Size] setting and [Output Size] setting are different
The print is automatically reduced or enlarged to fit on the page.
7
Specify the settings for [Paper Source] and [Paper Type].
(1)
Display the [Paper Source] sheet.
(2)
Set the paper source you want to use.
(3)
Select the type of the paper loaded in the paper source.*
Specify the setting according to the paper type as follows.
Paper Type
Setting for [Paper Type]
Plain Paper
16.0 to 23.9 lb Bond (60 to 90 g/m²)
[Plain]
[Plain L]**
Heavy paper
24.0 lb Bond to 55.5 lb Cover (91 to 150 g/m²)
[Heavy 1]
55.6 lb Cover to 60.3 lb Cover (151 to 163 g/m²)
[Heavy 2]
Transparency
[Transparency]
Label
[Labels]
Index Card
[Envelope]
Envelope
[Envelope]
If the printed paper curls (the printed side curls outward) when printed with [Plain] selected, select [Plain L].
Using Preview to specify a paper source
You can also specify a paper source by clicking each paper source or [Auto] using Preview when [ ] is selected.
8
Specify the other printing preferences as needed.
"Useful Printing Functions" describes the printing procedures that use the various printing functions. Make full use of the functions of this printer.
For details on the settings
See Help of the printer driver.
9
Confirm the settings, and then click [OK].
The [Print] dialog box reappears.
10
Click [OK].
The printer starts printing.
 If the printer cannot print properly
051R-03E
