Available Administrator Settings Table (Remote UI)
If the administrator is specified, you can restrict operations by general users and allow the administrator to set the settings of each function from
(Settings/Registration). This section describes the settings in
(Settings/Registration) that the administrator can operate.
Settings in [Adjustment/Maintenance] (Settings/Registration) cannot be set from the Remote UI.
If the administrator is specified, the settings below in Preferences can be set only by the administrator.
[Restart Device]
[Paper Settings]
[Paper Settings]
[Paper Type Management Settings]
[Display Settings]
[Edit Puncher Unit Die Name]
[Timer/Energy Settings]
[Date/Time Settings]
[Time Format]
[Auto Reset]
[Restrict Auto Reset Time]
[Power Save Settings]
[Perfect Binder Energy Saver Settings]
[Network Settings]
[Output Report]
[TCP/IP Settings]
[FTP PASV Mode Settings]
[HTTP Settings]
[SSL Settings]
[Proxy Settings]
If the administrator is specified, the settings below in Function Settings can be set only by the administrator.
[Common Settings]
[Paper Feed Settings]
[Paper Drawer Auto Selection/Paper Drawer Auto Selection Based on Color]
[Suspended Job Settings]
[Paper Output Settings]
[Output Tray Settings]
[Offset Jobs]
[Job Separator Between Jobs]
[Job Separator Between Copies]
[Insert Job Separator After Removing Stacker Paper Jam]
[Different Paper Sizes for Output Tray]
[Stacker Settings]
[Align Output Paper of Different Sizes]
[Unprocessed Tab Paper Forced Output]
[Print Settings]
[Print Priority]
[Output Report Default Settings]
[Form for Superimpose Image]
[Superimpose Image Quality Priority]
[Register Characters for Page Number/Watermark]
[Copy Set Numbering Option Settings]
[Scan Settings]
[Timing to Raise Feeder Tray]
[Feeder Jam Recovery Method]
[Scanner Noise Settings]
[Streak Prevention]
[Black & White Scan Speed/Image Quality Priority]
[LTRR/STMT Original Selection]
[Remote Scan Gamma Value]
[Generate File]
[Format PDF to PDF/A]
[Optimize PDF for Web]
[Rights Management Server Settings]
[Set Authentication Method]
[Copy]
[Select Color Settings for Copy]
[Printer]
[Custom Settings]
[Send]
[Output Report]
[TX/RX User Data List]
[Common Settings]
[TX Report/Communication Management Report]
[Network Settings - E-Mail/I-Fax Settings]
[Communications Settings - E-Mail/I-Fax Settings]
[Limit New Destination]
[Favorite Settings]
[Receive/Forward]
[Output Report]
[Common Settings]
[Divided Data RX Timeout/Always Send Notice for RX Errors]
[Forwarding Settings]
[Memory Lock Settings]
[Store/Access Files]
[Settings for All Mail Boxes]
[Box Security Settings]
If the administrator is specified, the settings below in Set Destination can be set only by the administrator.
[Set Destination]
[Address Lists (Output Report)]
[Address Book PIN]
[Manage Address Book Access Numbers]
[Address Book Export Settings]
[Register LDAP Server]
[Register/Edit LDAP Search]
[Acquire Remote Address Book]
[Make Remote Address Book Open]
If the administrator is specified, the settings below in Management Settings can be set only by the administrator.
[User Management]
[System Manager/Contact Person Information Settings]
[Department ID Management]
[Device Management]
[Device Information Settings]
[Certificate Settings]
[Key and Certificate Settings]
[CA Certificate Settings]
[Certificate Revocation List (CRL) Settings]
[Display Job Status Before Authentication]
[Display Job Log]
[Save Audit Log]
[Export/Clear Audit Log]
[Key Operation Log Store Settings]
[Encryption Method Settings]
[Remote Shutdown]
[License/Other]
[Message Board/Support Link]
[Remote UI Settings]
[Remote Operation Settings]
[Register/Update Software]
[Data Management]
[HDD Data Complete Deletion]
[Import/Export All]
[Import]
[Export]
[Import/Export Results]
[Import/Export Individually]
[Address Lists]
[Device Settings (Forwarding Settings, Address Book, Send Function Favorite Settings)]
[Printer Settings]
[Paper Information]
[Back Up/Restore Settings]
[Backup Location Settings]
[Auto Backup Settings]
[Back Up]
[Restore]
[Back Up/Restore Log]
