Make sure that the only administrator operates import and export functions.
Setting information is overwritten when operating the import function. Please note that the machine may malfunction or problem may occur as the result of overwritten data. The followings are examples:
For more information on the conditions of the Import All function, see "Available Settings Information Table with the Import All Function." Reconfiguration is required for some settings information.
If you import the Department ID Management settings, system manager information settings such as IDs and passwords are overwritten.
If the system settings of the exporting machine are different from those for importing, you may not be able to connect the machine to a network.
When operating the import function, original address books and address lists are overwritten.
Settings which are related to each other, such as forwarding settings and address lists, should be imported together, or reconfiguration is required. The machine may malfunction if those settings conflict each other.
If [Time Until File Auto Delete] in [Mail Box Settings] (Settings/Registration) is specified, files are deleted at the specified time.
If [Handle Files with Forwarding Errors] (Settings/Registration) is set to 'Off', jobs with forwarding errors are deleted.
The Import/Export operation may take some time to complete. Do not turn the machine's main power OFF until the operation is complete. Otherwise, the machine may malfunction.
During an Export operation, the screen display does not change until the operation is complete. Do not click [Start Exporting] while the hourglass or pointer indicates that the operation is still being processed.
The machine's control panel cannot be used while files are being imported/exported.
