Starting the Remote UI
To start the Remote UI, follow the procedure described below.
The portal page appears when you start the Remote UI. You can check the current status of the device including consumable information on the portal page.
Start your Web browser → enter the following URL in the address bar.
http://<IP address of the imagePRESS Server>/
Click [Launch Remote UI] in the Web Tool screen.
If the Remote UI does not start properly and an error message appears, delete the cache files of your Web browser.
When you use WebTools connecting directly the monitor or keyboard to the imagePRESS Server, you cannot start the Remote UI.
If you are logging in as an administrator, select [System Manager Mode] → enter the System Manager ID and System Manager PIN →click [Log In]. If you are a general user, select [General User Mode] → enter PIN → click [Log In].
When a Department ID Management is not set
If Department ID Management are set, enter the Department ID and password to log in.
» Remote UI » Starting the Remote UI
0S9Y-1CY
