If you import an Address List (Delete and Overwrite) or Forwarding Settings, the information stored in [Favorite Settings] from the control panel of the machine and Recall memory are erased.
Address List:
Select the Address List to be imported.
Import Method:
Select the import method for the Address List selected in <Address Lists>.
[Add]: The addresses in the file are added to the address list selected in <Address Lists>. No changes are made to the pre-existing addresses. Addresses in the file that have the same name as those already stored on the machine will treated as new registrations with the same name.
[Delete and Overwrite]: All addresses stored in the Address List selected in <Address Lists> are deleted, and the contents of the file are loaded into the machine.
File Path:
Specify the location of the file to load.
File Format:
Select the format specified when the file was exported.
[Custom Format]: The dedicated file format for Canon machines.
[LDAP Format]: Select this if the file is to be used by another application (e.g., Microsoft Internet Explorer, Netscape Navigator, Microsoft Outlook, Eudora, etc.).
If you select [One-Touch] for <Address Lists>, you cannot select [Add] for <Import Method>. Therefore, each one-touch button destination registered in the machine is overwritten when you perform the import procedure. You can also only import files exported with [Custom Format] selected.
You can register up to 1,800 addresses in the Address List. (200 of these are addresses assigned to the one-touch buttons.) Each address is treated as a separate item. When importing additional addresses, make sure that you do not exceed an overall total of 1,800 addresses.
When importing an LDAP format file, entries with e-mail addresses are imported into the machine. Make sure that the number of destinations to register does not exceed 1,800.
The name of the Address List is not imported.
File Format:
Select the format of the file that is to be exported. The file format for exported device settings differs according to the model of your machine. Check the exported file.
[FIM Format (Forwarding Settings, Address Book and Send Function Favorite Settings)]:
The file extension is ".fim." Files saved in this format include the Address List, Forwarding Settings, and Favorite Settings. When you export the device settings of the machine, the file is saved in this format.
[FIA Format (Forwarding Settings and Address Book)]/[FIL Format (Forwarding Settings and Address Book)]:
The file extension is ".fia"/".fil." Files saved in this format include the Address List and Forwarding Settings. When you export the device settings of a different model machine, the file may be saved in this format.
File Path:
If you import the device settings, the Address List is also imported, causing the registered destinations to be deleted and overwritten with the destinations in the imported file.
The machine must be restarted to enable the imported device settings. After importing, turn OFF the main power of the machine, and turn the main power back ON again.
After importing device settings, the Remote UI cannot be used to perform other operations until the machine is restarted. Turn OFF the main power of the machine, and turn the main power back ON again.
If the data exported from this machine is imported to a different model machine, [Favorite Settings] on the control panel is not updated.
If you specify the address in the Remote Address Book as the forwarding destination, the forwarding settings will not be imported. However, if the machine, which exports setting information, and the target machine for importing use the same Remote Address Book, the forwarding settings can be used in the target machine for importing. For more information on the Remote Address Book, see (See "Specifying Destinations Using the Address Book (Remote).")
Do not import any files while the machine is executing other jobs.
For instructions on turning ON/OFF the machine, see "Main Power and Energy Saver Key."
Category:
Select the category of paper information to update.
File Path:
When receiving paper information, you can specify whether to register all received paper information or only the basic information of each paper type. (See "Setting the Update Range of the Delivered Paper Information.")
You cannot import a file while the machine is scanning.
