e-ManualTopSite mapHelp
Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Use Cover Inserter
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Device Link Profile
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Spot Color Matching
Composite Overprint
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Mode
Device Link Profile
ICC Profile Settings
Photo Correct. (Color Only)
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
Output Profile
Matching Method
Device Link Profile
Halftones
Brightness
Spot Color Matching
Composite Overprint
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug and Play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Configuration Page
Configuration Page
0L3X-1UW
The Configuration Page includes the following information:
<1>
Hardware Configuration
This section displays the hardware configuration of the machine, including any options that have been installed.
<2>
Common Settings
This section displays the common printer settings of the machine, as determined by the Settings menu. (See "Building/Printing a Bar Code.")
<3>
Paper Feed
This section displays the paper feed settings for the printer function of the machine, as determined by the Paper Feed section of the Settings menu. (See "Paper Feed.")
<4>
Print Quality
This section displays the print quality settings for the printer function of the machine, as determined by the Print Quality section of the Settings menu. (See "Print Quality.")
<5>
Layout
This section displays the layout settings for the printer function of the machine, as determined by the Layout section of the Settings menu. (See "Control Codes.")
<6>
Copy Set Numbering
This section displays the Copy Set Numbering settings for the printer function of the machine, as determined by the Copy Set Numbering section of the Settings menu. (See "Copy Set Numbering.")
<7>
PCL Settings
This section displays the PCL settings for the printer function of the machine, as determined by the PCL section of the Settings menu. (See "PCL Settings.")
<8>
PS Settings
This section displays the PS settings for the printer function of the machine, as determined by the PS section of the Settings menu. (See "PS Settings.")
These samples are only applicable for the PCL or PS Printer.
