On
Please note that the memory of the machine can store up to 6,000 pages. When you send a secured document to be stored in the memory to be printed at a later time, and the memory is full (already reached its maximum capacity), your document will not be stored. The memory may be full because the machine is being used for other functions (such as storing a document in an inbox or storing a form) or other jobs, which use memory space.
This function can only be selected if the Saddle Finisher-AM2/Booklet Finisher-T1 is attached to the machine.
This function is not available if 'Booklet' is set to [Off].
If the print job contains only one sheet of paper, the paper will be folded but not stapled.
If you are using the Saddle Finisher-AM2, the maximum number of sheets that can be saddle stitched is 25. If the number of sheets is greater than this, they will not be saddle stitched.
If you are using the Booklet Finisher-T1, the maximum number of sheets that can be saddle stitched is 16. If the number of sheets is greater than this, they will not be saddle stitched.
