0L3X-1R9
RGB Input (Light+ClrSpace)
[D50 + sRGB]*, [D65 + sRGB], [D50 + Adobe RGB], [D65 + Adobe RGB], [Profile Name]
This setting enables you to perform color matching by specifying the RGB input device link profile setting for RGB input data.
Performs color matching to match the conditions of ambient light D50 (5,000 K) on an sRGB compatible monitor.
Performs color matching to match the conditions of ambient light D65 (6,500 K) on an sRGB compatible monitor.
Performs color matching to match the conditions of ambient light D50 (5,000K) on an Adobe RGB compatible monitor.
Performs color matching to match the conditions of ambient light D65 (6,500K) on an Adobe RGB compatible monitor.
You can specify a profile name by selecting a downloaded Device Link Profile on the machine.
CMYK Input (Light+ClrSpace)
[D50 + JapanColor]*, [Profile Name]
This setting enables you to perform color matching that supports device link profile, for CMYK data.
Performs color matching to match the conditions for JapanColor by using ambient light D50 (5,000K).
If the color mode is set to [Black & White], the device link profile setting is invalid.
This setting can be specified only if [D. Link Profile] is selected in [RGB Input] in [Matching Mode].
The Device Link Profile is not applied to Device Grey, CIE Based ABC, CIE Based DEF, CIE Based DEFG, or CIE Based A. Even if the Device Link Profile is specified, regular processing is applied for the ICC Profile.
