Top » Web Access » Customizing Settings » Cache Settings
Cache Settings
06RH-193
You can specify settings for the cache (temporary files of previously visited Web pages that are stored to speed up repeated access to the same page). This can prevent other users from viewing Web pages that you previously browsed.
Press [Function Settings] → [Web Access] → [Settings].
Press [Cache].
4.
Specify the settings for the cache.
If you want to set what type of cache to use:
If you want to delete the cache:
Press [Use Cache].
Select [On] for [Use Cache] → select the cache type → press [OK].
If you set it to 'On', you can select the following modes:
[Each Session]:
Checks the date and time information every time the machine starts up, and downloads from the server if the contents have been updated, or from the cache if the contents have not been updated.
[Each Access]:
Checks the date and time information every time the Web page is accessed, and downloads from the server if the contents have been updated, or from the cache if the contents have not been updated.
[Cache Priority]:
Does not check the date and time information, and downloads the contents from the server if the cache is not saved, or from the cache if they have been saved in the cache.
If this setting is set to 'Off', regardless of whether or not the cache is saved, the contents of the Web page are obtained from the server.
Press [Clear Cache].
It may take several minutes for the cache to clear, depending on the amount of data saved in the cache.
Press [Yes].
The cache is deleted.
If you do not want to delete the cache, press [No].
The default setting for [Use Cache] is 'Off'.
