Top » Web Access » Customizing Settings » Security Settings
Security Settings
06RH-18X
You can select whether to use SSL and specify settings for certificates that are used to connect to the server.
The default settings are:
Use SSL 2.0: On
Use SSL 3.0: On
Use TLS 1.0: On
Display Mixed HTTPS/HTTP Pg: On
Display Server Certificate Auth. Warning: Off
Displ Warning when Entering Secured Page: Off
Displ. Warning when Leaving Secured Page: Off
