Top » Web Access » Customizing Settings » Cookie Settings
Cookie Settings
06RH-194
You can specify cookie settings or set entry restrictions. A cookie is data that is temporarily stored when you browse a Web page. It records data such as the number of times the Web page is browsed and the date/time of when the Web page was accessed for user identification.
Press [Function Settings] → [Web Access] → [Settings].
Press [Cookie].
4.
Specify the settings for cookies.
If you want to specify the settings for receiving cookies:
If you want to erase cookies:
Press [Cookie Handling] → select whether to receive cookies → press [OK].
Details of each item are shown below.
Accept:
Always accepts the cookies that are created each time the user accesses a Web page.
Block:
Blocks all cookies.
Prompt:
Displays a screen prompting the user to select whether to accept or block the cookies created each time the user accesses a Web page.
Press [Delete Cookies].
Press [Yes].
This procedure deletes all cookies.
The default setting for [Cookie Handling] is 'Accept'.
Cookies are deleted after the Auto Clear mode initiates.
