0UKW-01Y
You can print various types of reports from the machine, to check settings and logs. Some reports are printed automatically, and some are printed manually. You can also set to print some reports automatically only when an error occurs.
You can print the following types of reports from the machine.
The Counter Report contains the number of pages printed.
The Page Count List contains the Printer counter information for each department.
The Print Log List contains the print job history.
The Device Information Delivery Destination List contains information about registered delivery destinations.
This report is a list which enables you to check the access logs for device information.
Prints the registration information for Settings/Registration. This is useful for checking settings details.
You can print the information for the applications installed in MEAP and some system application information.
You can print a list of the IPSec policies and confirm their priorities.
You can print a configuration page and font list for the PCL or PS Printer.
This report is used to check whether all the data and settings have been successfully initialized.
The following conditions must be met for a report to be printed:
There is a paper drawer with [Other] in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration) set to 'On'.
One of the following paper sizes is loaded in that paper drawer:
LGL
LTR
The loaded paper is one of the following types:
Plain 1 (17 lb bond to 20 lb bond (64 to 75 g/m2))
Plain 2 (21 lb bond to 24 lb bond (76 to 90 g/m2))
Plain 3 (25 lb bond to 28 lb bond (91 to 105 g/m2))
Recycled 1 (17 lb bond to 20 lb bond (64 to 75 g/m2))
Recycled 2 (21 lb bond to 24 lb bond (76 to 90 g/m2))
Recycled 3 (25 lb bond to 28 lb bond (91 to 105 g/m2))
Thin (16 lb bond (60 to 63 g/m2))
Color (17 lb bond to 20 lb bond (64 to 75 g/m2))
