e-ManualTopSite mapHelp
Top » Basic Operations » Screens Displayed on the Touch Panel Display » Setting Shortcut Buttons
0UKW-00W
This section describes how to specify the display settings for the shortcut buttons using the on the top right of the screen.
You can display up to four function shortcut buttons on the left of the screen.
Press the shortcut button you want to display → select the function to register in the shortcut button. If you do not want to select a function, press [Unassigned].
The shortcut buttons are displayed in the position of their shortcut number. If you only register Shortcut 3, nothing is displayed in the position for Shortcut 1, 2, and 4, and a button is only displayed in the position for Shortcut 3.
