To configure the printer option settings, you must log on to your computer as a member of the Administrators group.
If you are using Windows 8/8.1/Server 2012/2012 R2, from the desktop, display the charm bar to the right of the screen, and click or tap [
![]() For Windows Vista/Server 2008, click [
![]() For Windows XP Professional/Server 2003, click [Start] → [Printers and Faxes].
For Windows XP Home Edition, click [Start] → [Control Panel] → [Printers and Other Hardware] → [Printers and Faxes].
If you are using a shared printer, you need to install Canon Driver Information Assist Service in the print server computer in order to use the [Get Device Status] function. For details about how to install the Canon Driver Information Assist Service, see the Printer Driver Installation Guide (see "Installation").
If the information request returns an error message, you need to configure the settings (such as paper feed options, paper output options, etc.) manually.
If the printer and computer are connected via USB or a WSD (Web Services on Devices) port, the [Get Device Status] function is unavailable. You need to configure the settings manually.
Depending on the printer model you are using, you may need to click [Function] and set the function version of the printer. You can confirm the function version of the printer by printing a status report from the control panel of the printer.
