Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Compressed Image Output
Initialize
UFR II Settings
Halftones
Matching Method
Gray Compensation
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
Matching Method
Gray Compensation
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Method
Photo Correct. (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
XPS Settings
Matching Method
Halftones
Gray Compensation
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Paper Feed
Paper Feed
0R9W-1EL
Default Paper Size
[Letter]*, [Legal], [A4], [B5], [A3], [B4], [A5], [11x17], [Executive], [Statement], [Env. KAKUGATA 2], [Env. NAGAGATA 3], [Env. YOGATANAGA3], [Envelope Monarch], [Env. No. 10], [Envelope ISO-C5], [Envelope DL], [12x18], [12_5/8x17_11/16]
This parameter defines the default paper size used when the paper size cannot be set within the application software, when no paper source is specified.
Default Paper Type
[Thin], [Plain 1]*, [Plain 2], [Plain 3], [Heavy 1], [Heavy 2], [Heavy 3], [Heavy 4], [Color], [Recycled 1], [Recycled 2], [Recycled 3], [Pre-Punched], [Transparency], [Tracing], [Labels], [Bond], [1-Sided Coated 1], [1-Sided Coated 2], [1-Sided Coated 3], [2-Sided Coated 1], [2-Sided Coated 2], [2-Sided Coated 3], [Envelope]
This parameter sets the default paper type to be used for print jobs. This machine has internally defined optimal print modes for each specified paper type.
Paper Size Override
[On], [Off]*
If paper of the size that is set in the printer driver has not been loaded in the paper drawer, the paper that is printed is changed to the following sizes.
Printer Driver Setting
Paper
Letter
A4
A4
Letter
11" x 17"
A3
A3
11" x 17"
[On]
The paper size is changed. If there is no paper in the paper source of the size that is set in the printer driver, the paper supply message is displayed and the paper size is not changed.
[Off]
The paper supply message is displayed and the paper size is not changed.
If you are printing from an OS that lacks a printer driver for the machine (MS-DOS, UNIX, etc.), make sure that the paper loaded in the paper drawer matches the paper size specified in this setting. If the paper size specified in this setting is not available, an error message is displayed when the machine tries to print the job and the machine stops. In addition, if a paper source has not been selected through the application, the machine automatically selects the default print settings for the paper size and type. (See "Enabling Paper Drawer Auto Selection.")
Use the following figures as a guideline to decide whether paper should be specified as Plain Paper or Heavy Paper.
Plain Paper: 17 lb bond to 28 lb bond (64 g/m2 to 105 g/m2)
Heavy Paper: 29 lb bond to 140 lb index (106 g/m2 to 256 g/m2)
Canon transparency film is recommended for printing on transparencies.
Canon label paper is recommended for printing on labels.
Thin, Plain 1, 2, and 3, Heavy 1, 2, and 3, Color, Recycled 1, 2, and 3, Pre-punched, and Bond can be printed using two-sided printing.
