Inner Finisher-G1
Inner 2way Tray-J1, Copy Tray-J2
Staple Finisher-U1, Booklet Finisher-U1
Collate
Group
Rotate+Collate
Rotate+Group
Offset+Collate
Offset+Group
Staple+Collate
Staple+Group
Eco(Stpl-Fr)+Col
Eco(Stpl-Fr)+Grp
Off
Collate
Group
Rotate+Collate
Rotate+Group
Offset+Collate
Offset+Group
Staple+Collate, Eco(Stpl-Fr)+Col
Staple+Group, Eco(Stpl-Fr)+Grp
A large print job may be automatically canceled by the machine. The maximum number of pages that can be printed at one time is approximately 6,000 pages. However, this number may be fewer than 6,000 if other functions (such as storing a document in an inbox) are in use, or other jobs are being processed.
[Offset+Collate] and [Offset+Group] are available if you select the following paper size:
When the Inner Finisher-G1, Staple Finisher-U1, or the Booklet Finisher-U1 is attached: A3, B4, A4, A4R, B5, 11"x17", LGL, LTR, LTRR, EXEC
[Corner (Upper-L)]
[Double (Top)]
[Corner (Upper-R)]
[Double (Right)]
[Corner (Lower-R)]
[Double (Bottom)]
[Corner (Lower-L)]
[Double (Left)]
When you are stapling paper in landscape orientation, the image orientation and the staple position may not match.
Corner (Upper-Left)
Double (Top)
Corner (Upper-Right)
Double (Right)
Corner (Lower-Right)
Double (Bottom)
Corner (Lower-Left)
Double (Left)
11" x 17"
LGL
LTR
LTRR
EXEC
A3
B4
A4
A4R
B5
The maximum number of sheets of plain type paper that can be stapled at one time is:
A3, B4, A4R, 11" x 17", LGL, LTRR: 30 sheets
A4, B5, LTR, EXEC: 50 sheets
The size and number of sheets of plain paper that can be stapled with the Eco (Staple-Free) mode are:
A3, B4, A4, B5, 11" x 17", LTR: 5sheets
