0R9W-1JU
[Text]: [Normal], [Photo], [TR Normal], [TR Photo]*, [Download Profile]
[Graphics]: [Normal], [Photo], [TR Normal], [TR Photo]*, [Download Profile]
[Image]: [Normal], [Photo], [TR Normal], [TR Photo]*, [Download Profile]
This setting allows you to define the profile that is appropriate for the data you are going to print. It is applied to all data in the print job, so make sure the selected profile is right for your job.
Settings can be applied separately for text, graphics, and image data.
This setting prints the colors closely matching the ones displayed on your monitor.
This setting prints colors close to photographic prints.
This setting prints the colors closely matching the ones displayed on your monitor, and prints black and grey data (comprised of equal red, green, and blue components) using only black (Bk) toner.
This setting prints the colors close to photographic prints, and prints black and grey data (comprised of equal red, green, and blue components) using only black (Bk) toner.
Set this to use profiles downloaded to the machine. Up to 100 profiles can be saved.
You can also download the profile from imageWARE Enterprise Management Console.
If [None] is selected for the 'RGB Source Profile' or 'CMYK Simulation Profile', or if [Off] is selected for 'Use Grayscale Profile', an Output Profile setting is not applied to device dependent color data.
