Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Compressed Image Output
Initialize
UFR II Settings
Halftones
Matching Method
Gray Compensation
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
Matching Method
Gray Compensation
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Method
Photo Correct. (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
XPS Settings
Matching Method
Halftones
Gray Compensation
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Print Quality
Print Quality
0R9W-1ER
Density
[Cyan]
-8 to +8; 0*
[Magenta]
-8 to +8; 0*
[Yellow]
-8 to +8; 0*
[Black]
-8 to +8; 0*
This mode is not available if you set [Toner Save] to [On].
This setting adjusts the print density.
Pressing [Dark] makes the print image darker, pressing [Light] makes the image lighter.
Density (Fine Adjust)
[Cyan]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Magenta]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Yellow]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Black]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
This setting adjusts the print density of the respective colors.
Toner Save
[On], [Off]*
This setting enables you to set the Toner Save mode. Toner Save uses less toner to print documents and may result in longer toner life.
Depending on the data to be printed, the Toner Save mode may not be applied even if you select [On].
If you select [On] for [Toner Save], very light or finely detailed images may not be printed clearly.
Gradation
[Standard], [High 1]*, [High 2]
[Standard]: Creates two-color gradation data (1 bit/pixel)
[High 1]: Creates four-color gradation data (2 bit/pixel)
[High 2]: Creates 16-color gradation data (4 bit/pixel)
Default Settings
The default Gradation setting automatically switches according to the Resolution setting (600 dpi, 1200 dpi).
If you set the Resolution to [600 dpi], the Gradation mode will automatically switch to [High 1].
If you set the Resolution to [600 dpi], the following restriction applies:
You can only select [High 1] or [High 2] for the Gradation mode.
If you set Resolution to [600 dpi] and Gradation to [Printer Default], the Gradation mode will automatically switch to [High 1] even if it is set to [Standard].
If you set the Resolution to [1200 dpi], the following restrictions apply:
You can only select [Standard] for the Gradation mode.
If you set Resolution to [1200 dpi] and Gradation to [Printer Default], the Gradation mode will automatically switch to [Standard] even if it is set to [High 1] or [High 2].
Resolution
[1200 dpi], [600 dpi]*
This setting specifies the resolution for printing.
Resolution is expressed in units of dpi (dots per inch), indicating the number of dots in one inch. The higher the value, the greater the resolution, allowing finer expression of detail.
[1200 dpi]
The outline of characters and diagrams can be finely printed. This is suited to printing data containing fine lines and small characters.
[600 dpi]
You can perform printing suited to general documents and tables.
If you select [1200 dpi] for [Resolution], you cannot specify the following settings: rotate collate, different paper sizes (LTR/LGL), and double stapling on the short edge of A4 and LTR size paper.
When printing on large scale paper, set [Resolution] to [600 dpi]. If you select [1200 dpi], there will not be enough memory necessary to process printing and printing will not be possible.
Sharpness (Photo)
[On], [Off]*
[Low], [Medium]*, [High]
This mode is not available if you set [Sharpness (Photo)] to [Off].
This setting enables you to adjust the image sharpness. The default is 'Medium'. Select [High] to make image outlines clearer than [Medium], and [Low] to make image outlines blurred.
Special Smoothing Mode
[Mode 1]*, [Mode 2], [Mode 3], [Mode 4], [Mode 5], [Mode 6]
This setting specifies the mode for special smoothing processing. Special smoothing processing corrects vertical color misalignment, which enables you to smoothly print characters, lines, diagrams, images (photos), and gradations that have dark colors.
[Mode 1]:
Smoothly prints the edges of characters, lines, and diagrams that have dark colors. Select [Mode 1] to perform printing normally.
[Mode 2]:
Smoothly prints not only the edges of diagrams, but also the halftones inside the diagrams. Set [Mode 2] if large characters and halftones inside fat lines that have dark colors are misaligned and not printed smoothly when printing with [Mode 1] set.
[Mode 3]:
Smoothly prints characters and lines that have dark colors on a halftone background. Set [Mode 3] if large characters and halftones inside fat lines that have dark colors are misaligned, or when the edges of characters and lines that have light colors are uneven, and not printed smoothly when printing with [Mode 1] set.
[Mode 4]:
Smoothly prints the edges of various objects. Set [Mode 4] if the edges of large characters and fat lines that have light colors are uneven and not printed smoothly when printing with [Mode 1] set.
[Mode 5]:
Evenly prints images and halftone objects. Set [Mode 5] if the gradation bands of images and diagrams are uneven or the dithering patterns are uneven when printing with [Mode 1] set.
[Mode 6]:
Evenly prints all objects. Set [Mode 6] if the halftones of the entire image are misaligned and uneven when printing with [Mode 1] set.
If [Resolution] is set to [1200 dpi], the [Mode 1] to [Mode 4] settings are disabled and the same processing as [Mode 5] is performed.
If [Error Diffusion] is set in [Halftones], the [Mode 1] to [Mode 4] settings are disabled, and the same processing as [Mode 6] is performed.
Toner Volume Correction
[Normal]*, [Grad. Priority], [Text Priority]
This setting enables you to set the Toner Save function. Toner Save uses less toner to print documents and may result in longer toner life.
[Normal]
Text and line data are printed with a toner volume that upholds the resolution for text and lines. Other types of data are printed with a toner volume that upholds the color.
[Grad. Priority]
All data is printed with a toner volume that upholds the color.
[Text Priority]
All data is printed with a toner volume that upholds the resolution.
The internal restriction value cannot be changed.
This setting can only be applied to jobs in the PS mode and PDF mode.
If [Grad. Priority] is selected, characters and lines may bleed.
If [Text Priority] is selected, the color may not match.
Line Control
[Res. Priority]*, [Grad. Priority]
This setting enables you to specify the image processing for lines. Under most circumstances, it is preferable to leave this setting as [Res. Priority].
[Res. Priority]
Image processing is performed that upholds the same resolution as text for lines.
[Grad. Priority]
Image processing is performed that upholds the same color and gradation as graphics for lines.
The Line Control mode can only be applied to jobs in the UFR II mode, PCL6 mode, PS mode, and PDF mode.
Advanced Smoothing
[Advanced Smoothing]: [Off], [Level 1]*, [Level 2]
[Apply to Graphics]: [On], [Off]*
[Apply to Text]: [On]*, [Off]
This setting smoothes jagged outlines of graphics (illustrations created by application software) and characters.
[Level 2] performs a higher level of smoothing than [Level 1]. If [Level 1] is selected and the results are still not printed smoothly, select [Level 2].
By switching the on/off for 'Graphics' and 'Text', you can select whether to apply smoothing to graphics or text data.
This setting allows you to apply smoothing to graphics data and text data. Smoothing is not applied to image data.
When [Resolution] is set to [1200 dpi] and [Halftones] is set to [Error Diffusion], this function is disabled.
"Apply to Graphics" and "Apply to Text" can only be selected when [Level 1] or [Level 2] is selected for Advanced Smoothing.
Settings for "Apply to Graphics" and "Apply to Text" on the touch panel display will be effective only if 'Printer Default' is set for Advanced Smoothing in the printer driver.
The results of Advanced Smoothing may differ depending on the characters and graphics patterns.
Gradation Smoothing
[Gradation Smoothing]: [Off]*, [Level 1], [Level 2]
[Apply to Graphics]: [On]*, [Off]
[Apply to Images]: [On]*, [Off]
Set this function when the gradation of graphics (illustrations made by software applications) or images (bitmap images) does not print smoothly (the color changes stand out).
[Level 2] performs a smoother gradation than [Level 1]. If [Level 1] is selected and gradation is still not printed smoothly, select [Level 2]. You can select whether to apply smoothing to graphics or image data.
This setting does not apply to text data.
If [Level 1] or [Level 2] is selected, and gradation is applied to halftones, graphics and images may appear grainy.
"Apply to Graphics" and "Apply to Images" are only displayed when [Level 1] or [Level 2] is selected.
