0R9W-1K0
[On], [Off]*
You can overprint device-dependent CMYK data as composite output.
All colors used for data are overlaid and printed on one plate so you can check the finished result without separating the colors.
This setting is only available for data having the overprint attribute set.
This setting does not apply overprinting to spot colors.
