Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Compressed Image Output
Initialize
UFR II Settings
Halftones
Matching Method
Gray Compensation
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
Matching Method
Gray Compensation
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Method
Photo Correct. (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
XPS Settings
Matching Method
Halftones
Gray Compensation
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Bar Code Printing » Control Codes
Control Codes
0R9W-1L7
This section provides examples of commands that can be used to create bar codes.
PCL Escape Sequences
The escape sequence controls the character strings (Hexa: 1B or Dec: 27) that begin with <Esc>. By embedding and sending these character strings to this Bar Code Printing function in an unprintable, special character code, you can control details, such as the bar code size, as well as the caption text font and the space between the characters.
The following is an example of a valid PCL escape sequence:
<Esc>(s4p102h40v10,30b10,30s24670T
s4p:
Readable text that is located under the bars, without start or stop characters (*)
102h:
Caption text in Univers Regular
40v:
Bar height:
40 points
Formula:
40/72 = 0.555"
40*2.54/72 = 1.41 cm
10,30b:
Thin bars that are 10 dots wide, and thick bars that are 30 dots wide
10,30s:
Thin spaces that are 10 dots wide, and thick spaces that are 30 dots wide
24670T:
Symbol: code 39
Bar Code Rotation Codes
To rotate a bar code, you can use regular PCL rotation commands. We recommend that you save the cursor position before activating the bar code, and restore the original cursor position after the bar code is rotated.
Example: (Sequences should be entered without carriage returns.)
<Esc>&fS
Saves the cursor position.
<Esc>&a1000h1000V
Positions the cursor.
<Esc>&a90P
Rotates the bar code 90°.
Formats the bar code.
CANON
The bar code text data.
<Esc>(10U<Esc>(sp10hsb4099T
Switches back to Courier 10 cpi font.
<Esc>&aP
Stops the rotation.
<Esc>&lf1S
Restores the original cursor position.
Font Switching
You can switch primary and secondary fonts with bar code fonts. We recommend that a text font be used as the primary font, and a bar code font be used as the secondary font.
Bar codes are not PCL fonts, even if they are generated using a PCL font sequence. Therefore, the following font sequence limitations apply:
No font ID can be linked to a bar code
Bar codes cannot be used with HP-GL2, PostScript, or PCL XL languages
OCR-A and OCR-B Fonts
The following PCL escape sequences enable OCR-A and OCR-B fonts:
OCR-A:
<Esc>(0O<Esc>(sp10h12vsb104T
OCR-B:
<Esc>(1O<Esc>(sp10h12vsb110T
The above table shows the OCR-A character set.
FreeScape Codes
PCL codes always begin with the unprintable escape code Hexa: 1B or Dec: 27. Some systems cannot use or send binary data to a device, which can represent a problem when using the PCL language with bar codes. An example of this kind of system is a mainframe computer with printers connected to terminals. To avoid conflicts between the PCL language and bar codes in such a system, the FreeScape Code, a user-defined Escape Code or AEC (Alternate Escape Code) can be specified.
FreeScape acts exactly like the standard escape code when it is located at the beginning of a regular PCL font sequence. The default value for the AEC is a '~' (tilde). FreeScape ignores the AEC if it is determined to be pure data. You can also mix escape codes and alternate escape codes.
The AEC can be any one of the following 10 characters:
The PCL font sequence to change to the alternate escape code is as follows:
<Esc or AEC>**#J
# represents the ASCII decimal value of the new AEC or ESC. Values for AEC are 34 ("), 35 (#), 36 ($), 47 (/), 92 (\), 63 (?), 123 ({), 125 (}), 124 (|), or 126 (~). The value for ESC is 27. If you indicate 27, it disables the FreeScape Code.
The FreeScape escape sequence setting is only valid for the current job.
The FreeScape Code can be enabled, disabled, or set as a parameter for all jobs from the FreeScape menu in Printer Settings (from the Settings/Registration screen).
When FreeScape is disabled, only the escape code (Hexa: 1B or Dec: 27) can be used to start PCL commands.
