Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Printing Fundamentals
Printing
Viewing Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Mac OS)
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Viewing Help
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Compressed Image Output
Initialize
UFR II Settings
Halftones
Matching Method
Gray Compensation
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
Matching Method
Gray Compensation
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Method
Photo Correct. (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
XPS Settings
Matching Method
Halftones
Gray Compensation
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Layout
Layout
0R9W-1ES
Binding Location
[Long Edge]*, [Short Edge]
This parameter determines whether the binding position is along the long edge or the short edge of the paper. When binding for two-sided printing, the image orientation is automatically adjusted for correct layout.
[Long Edge]
When the binding position is on the long edge of the paper:
[Short Edge]
When the binding position is on the short edge of the paper:
Gutter
-1.90 inches to +1.90 inches; 0.00* inches
This setting enables you to set the page margin in inches. The settings can be set in increments of 0.01" (0.5 mm) from -1.90" (-50.0 mm) through +1.90" (+50.0 mm).
Use  to increase the width of the inside margin.
Use  to increase the width of the outside margin.
You can specify the edge along which the margin will be created in the Binding Location setting (previous setting). To create a margin along one of the edges of the paper, use this setting in combination with the Binding Location setting.
Offset Short Edge/Offset Long Edge (Front)
-2.00 inches to +2.00 inches; 0.00* inches
This setting enables you to set the offset position in inches. The settings can be set in increments of 0.01" (0.5 mm) from -2.00" (-50.0 mm) through +2.00" (+50.0 mm).
The print position on the front page is adjusted in the vertical or horizontal direction to the value specified in the setting value.
To adjust the print position on the back page, set the Offset Short Edge/Offset Long Edge (Back) mode (the next setting).
You can increase or decrease the setting in increments of 0.01" (0.5 mm) to adjust the print position, as described below.
[Offset Short Edge (Front)]
Increasing the setting value moves the image in the rightward X direction on the paper. Decreasing the setting value moves the image in the leftward X direction on the paper.
[Offset Long Edge (Front)]
Increasing the setting value moves the image in the downward Y direction on the paper. Decreasing the setting value moves the image in the upward Y direction on the paper.
The print position on the back page is adjusted in the vertical or horizontal direction to the value specified in the setting value.
To adjust the print position on the front page, set the Offset Short Edge/Offset Long Edge (Front) mode (the previous setting).
[Offset Short Edge (Back)]
[Offset Long Edge (Back)]
Please note that if the print position is adjusted to place print data outside the printable area, the portion outside the printable area is not printed.
If the gutter setting moves the image outside the printable area, part of the image may be cut off.
You cannot create a binding margin in the Binding Location mode alone. Use this setting in combination with the Margin setting to create a binding margin.
The orientation of the image on the back side of the page may be changed by the Binding Location mode for two-sided printing.
If the Gutter mode is used in combination with the Offset Short Edge/Offset Long Edge mode, the values of the two settings are added together.
Pressing increases the gutter setting value by 0.01" (0.5 mm) each time the key is pressed. Pressing decreases the value by 0.01" (0.5 mm) each time. Holding down either or continuously speeds up the value alteration.
Pressing increases the offset position setting value by 0.01" (0.5 mm) each time the key is pressed. Pressing decreases the value by 0.01" (0.5 mm) each time. Holding down either or continuously speeds up the value alteration.
If the Offset Short Edge/Offset Long Edge (Front) mode is used in combination with the Margin mode, the values of the two settings are added together.
If the Offset Short Edge/Offset Long Edge (Back) mode is used in combination with the Margin mode, the values of the two settings are added together.
