Category Top
Overview of This Function
Flow of Copy Operations
Canceling a Copy Job
Reserved Copying
Changing Color Modes
Copy Sample
Recalling Previous Copy Jobs (Previous Settings)
Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Assigning Shortcuts
Changing and Canceling Copy Settings
Interrupt Mode
Changing Basic Copy Ratios
Zoom by Length
Setting the X and Y Axes Independently
Poster
Paper Selection
Book→2 Pages
Two-Sided Copying
Collating Copies
Booklet Mode
Job Build
N on 1
Add Cover
Inserting Sheets
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Inserting Sheets When Copying Onto Transparencies
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock (TL Code)
Document Scan Lock (QR Code)
Adjusting the Color
One Touch Color Mode
Page Numbering
Copy Set Numbering
Adjusting the Image Sharpness
Erase Frame
Watermark Printing
Date Printing
Shifting the Original Image
Gutter Mode
Print & Check
Inverting Images (Nega/Posi)
Repeat Images
Merge Job Blocks
Job Done Notice
Mirror Image
Area Designation
Print on Tab
Store in Mail Box
Superimpose Image
Various Features of the Express Copy Basic Features Screen
Operating the Express Copy Basic Features Screen
Setting Shortcuts on the Express Copy Basic Features Screen
Appendix
For instructions on placing your originals, see "Placing Originals,"
If [Auto Collate] is set to 'On', the Collate or Offset Collate mode is automatically set when you place your originals in the feeder. (See "Enabling Auto Collating.")
to display the desired mode.
(numeric keys) to enter the desired copy quantity (1 to 9,999).
(Clear)→ enter the correct value.|
You cannot change the copy quantity while the machine is copying.
The number of copies which can be set varies according to the copy modes you have set.
(Start).
(Start) to scan each original.
To cancel copying, press
(Stop). For information on canceling copying, see "Canceling a Copy Job."For information on interrupting a copy job to make priority copies, see "Interrupt Mode."
For information on starting to copy the next original while a previous original is printing, see "Reserved Copying."
We recommend you read the following topics before using the Copy function:
Main Power and Energy Saver key (See "Main Power and Energy Saver Key.")
Entering Characters from the Touch Panel Display (See "Entering Characters from the Touch Panel Display.")
Routine Maintenance (See "Routine Cleaning.")
If you are using a login service, log in and out of the service before and after operating the machine.
If you are using Department ID Management with the Copy Card Reader-F1, see "Copy Card Reader-F1 (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "Copy Card Reader-F1 (imageRUNNER ADVANCE C7270/C7260)."
If you are using Department ID Management, see "Entering the Department ID and PIN."
If you are performing user authentication using the SSO-H login service, see "Login Service."
To cancel all settings and return the machine to the default mode, press
(Reset).For information on how to load paper, see the followings|
Paper Drawer: Loading Paper into a Paper Drawer
Multi-Purpose Tray: Loading Paper into the Multi-Purpose Tray
Paper Deck Unit-C1/POD Deck Lite-A1: (See "Loading Paper into the Paper Deck Unit-C1/POD Deck Lite-A1 (Optional).")
Multi-drawer Paper Deck-A1: (See "Loading Paper into the Multi-drawer Paper Deck-A1 (Optional).")
Document Insertion Unit-H1: (See "Loading Paper into the Document Insertion Unit-H1 (Optional).")
Document Insertion/Folding Unit-G1/Document Insertion Unit-J1: (See "Loading Paper into the Document Insertion/Folding Unit-G1/Document Insertion Unit-J1 (Optional).")
