Various Features of the Express Copy Basic Features Screen
This section describes the keys displayed on the Express Copy Basic Features screen. For detailed explanations of each mode/key, see the references in From the Regular Copy Basic Features Screen in the table below.
For instructions on operating the Express Copy Basic Features screen, see "Operating the Express Copy Basic Features Screen."
This screen enables you to set basic copying modes. You can set basic copying modes, such as the density or finishing mode, Favorite Settings and Previous Settings.
Key
Description
1
Select Color
You can select the color mode.
2
Adjusting Density Manually
You can adjust the copy density.
3
Copy Ratio
Press to specify the desired copy ratio.
4
Select Paper
Press to select the paper size/type and the paper source.
5
2-Sided
This mode enables you to make two-sided copies from one-sided or two-sided originals, or make one-sided copies from two-sided originals.
6
Finishing
This mode enables you to collate copies in various ways, by pages or copy sets
7
You can specify the following settings:
Register/Edit Favorite Settings
Register to Quick Menu
Changing the Default Settings
Register Options Shortcuts
8
Options
You can configure a range of copy functions.
9
Interrupt
The interrupt mode enables you to pause a reserved or current job to make higher priority copies.
10
Copy Sample
This mode enables you to check the copy result before making multiple copies.
11
Adjust Image Quality
You can adjust image quality to the level best suited for the quality of text or photo originals.
12
Shortcuts to [Options]
You can set up to six shortcuts.
13
Previous Settings
Press to recall the three most recent copy settings.
14
Favorite Settings
Press to register frequently used copy settings. You can also recall registered copy settings.
The modes for Options on the Express Copy Basic Features screen can be displayed on the Regular Copy Basic Features screen by pressing [Options].
For instructions on changing the display of the Copy Basic Features screen, see "Switching the Copy Basic Features Screen."
» Copy » Various Features of the Express Copy Basic Features Screen
08JK-0WA
