Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Available Paper Sizes
08KE-12W
When received documents are printed, they are printed from the paper drawer that has the same paper size as the received document.
If paper of the correct size is not available, the machine automatically selects a different paper size in the following order. (If all the switches in <Select Drawer> for [Select Drawer] (Settings/Registration) are set to 'On'.) The paper size is automatically selected in the same order, even if paper runs out during printing.
Available Paper Sizes for Received Documents
Size of Received Document
Paper Size Priority
11" x 17"
11" x 17" → LTR* → LTRR* → LGL* → STMTR x 2
LGL
LGL → LTR x 2 → LTRR x 2 → STMTR x 2 → 11" x 17"
LTR
LTR → LTRR → LGL → STMTR x 2 → 11" x 17"
STMT
STMTR → LTR → LTRR → LGL → 11" x 17"
* Received documents are automatically reduced before being printed on the paper size indicated.
Received documents can be printed on the following paper sizes and paper types:
Size: 11" x 17", LGL, LTR, LTRR, or STMTR
Paper Types: plain, recycled, color, or custom paper type (paper with the following settings; Basis Weight: 17 lb bond to 28 lb bond (64 to 105 g/m2), Type: Normal, Finish: Uncoated or Recycled)
You can specify each paper drawer for the I-fax function. (See "Enabling Paper Drawer Auto Selection.")
You can set the machine to reduce received documents in 1% increments between 75% to 97% if the document is larger than any of the available paper sizes. (See "Reducing a Received File.")
You can change the order of paper selection. (See "Paper Drawer Selection.")
You can set the machine to print received documents on both sides of the paper. (See "2-Sided Printing.")
