Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying Destinations » Setting Cc and Bcc Addresses
08KE-10K
You can set multiple e-mail address destinations as Cc (Carbon copy) and Bcc (Blind carbon copy) addresses in addition to the destinations for the documents.
Press [Scan and Send] → [Cc Bcc].
Specify e-mail addresses for Cc and Bcc.
To specify e-mail addresses for [Cc]:
To specify e-mail addresses for [Bcc]:
To move e-mail addresses from [To] or [Bcc] to [Cc]:
To move e-mail addresses from [To] or [Cc] to [Bcc]:
If you want to confirm or change an e-mail address that is already set, select the e-mail address → press [Details].
To delete an address, press [Delete Dest.].
Press [Cc] → [Specify Destinations].
Specify the e-mail address from [Address Book], [One-Touch], [New Destination], or [Send to Myself] → press [OK].
You can also browse destinations registered in the one-touch buttons of a server machine from a client machine on the network. (See "Specifying Destinations Using the One-Touch Buttons.")
Press [Bcc] → [Specify Destinations].
Press [Cc] → [To/Bcc|Cc].
[To/Bcc|Cc] appears only if [Cc] is selected.
Press [To] or [Bcc] → select the e-mail addresses you want to move to [Cc] → press [OK].
Press [Bcc] → [To/Cc|Bcc].
[To/Cc|Bcc] appears only if [Bcc] is selected.
Press [To] or [Cc] → select the e-mail addresses you want to move to [Bcc] → press [OK].
You can send to a combined maximum of 256 [To], Cc, and Bcc destinations at once.
[Send to Myself] appears only if you register a user's e-mail address when you are using authentication by SSO-H.
