Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Setting the Resolution
08KE-11E
Set the resolution to use for the scan. Scanning at high quality increases the file size, but ensures details are preserved in the final image.
Press [Scan and Send] → specify the destination → press the resolution button.
Select the resolution → press [OK].
To set the resolution to 200 x 400 dpi, 400 x 400 dpi, or 600 x 600 dpi when color mode is set to [Auto (Color/Gray)], [Auto (Color/Black)], [Full Color], or [Grayscale], it is necessary to install the Additional Memory Type D (512MB) to expand the memory capacity of the machine.
If the Additional Memory Type D (512MB) is not installed when setting the resolution to 200 x 400 dpi, 400 x 400 dpi, or 600 x 600 dpi, you cannot select [Auto (Color/Gray)], [Auto (Color/Black)], [Full Color], or [Grayscale].
If only an I-fax address is specified as the destination, you can set to the resolution to 200 x 400 dpi, 400 x 400 dpi, or 600 x 600 dpi. An I-fax original is always sent in the Black-and-White mode regardless color mode settings.
The maximum size of an image that you can send at 600 x 600 dpi resolution is 11" x 17". If the image exceeds this size, it may be cut off.
If you send a long strip original at 600 x 600 dpi, the periphery of the original image may be cut off slightly.
If [OOXML] is selected as the file format, you can only send in [300x300 dpi] or [600x600 dpi].
