Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying Destinations » Setting Your Personal Folder as the Destination
08KE-10H
A personal folder can be set for each authenticated user. You can specify your own folder as the destination.
A personal folder is enabled only if you are managing users by login service, such as SSO-H.
For information on how to specify a personal folder, see "Specifying Personal Folders."
Press [Scan and Send] → [Personal Folder].
If you are using a login service, it is necessary to log in to the machine with the appropriate procedure for the login service. To use SSO-H as the login service, see "Login Service."
If the screen for registering a personal folder is displayed after pressing [Personal Folder], you need to specify each item on the screen. For more information on each setting item, see "Specifying a File Server Using the Keyboard."
To verify/change the path of the personal folder or the authentication information, press on the top right of the screen → [Register/Edit Information for Each User] → [Personal Folder].
The administrator can limit the destination for file transmission to each personal folder of the general user. (See "Restricting Destination for File Transmission.")
