Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Preview
Preview
08KE-129
This mode enables you to preview the scanned data of your originals, and to check the page count before sending your document.
Press [Scan and Send].
Specify the destination → press [Options] → [Preview].
Press [Close].
4.
Press (Start).
5.
Press [Start Sending].
6.
Press or to select the page that you want to check.
You can press (reduce) or (enlarge) to zoom in or out.
You can press , , , or to specify the area to display when you zoom in or out on the page.
You can also delete scanned pages as necessary.
If you want to delete a single page:
If you want to delete multiple consecutive pages:
Press [Delete Pages] → [Single Page].
Press [-] or [+] to select the page you want to delete.
Press [Start Deleting] → [Yes].
Press [Delete Pages] → [Multiple Pages].
Press [First Page] → press [-] or [+] to select the first page of the range to delete.
Press [Last Page] → press [-] or [+] to select the last page of the range to delete.
7.
