Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying Destinations » Specifying a Destination by Entering an E-mail Address
08KE-106
Press [Scan and Send] → [New Destination].
Press [E-Mail].
Enter the e-mail address → press [OK].
If [Autocomplete for Entering E-Mail Addresses] is set to 'Off', press [E-Mail Address] → enter the e-mail address.
You can use the autocomplete function, if you set [Autocomplete for Entering E-Mail Addresses] to 'On'. (See "Setting Autocomplete for E-mail Address Entry.")
When you enter an e-mail address from the keyboard displayed on the touch panel display, e-mail addresses registered in the Local Address Book that match the initial characters of your e-mail address entry, automatically appear highlighted yellow.
To select the automatically displayed e-mail address, press [OK]. To enter a different e-mail address, enter the full destination address.
You can also specify a destination by pressing  to display a list of potential matches.
E-mail addresses that are stored with an access number do not appear.
4.
Select one of the following for <Divide Data>.
[On]:
Select [On] if the recipient's machine has a function to combine divided data that is received.
[Off]:
Select [Off] if the recipient's machine does not have a function to combine divided data or if you do not want to divide the sent data.
If the size of the data being sent exceeds the value set for [Maximum Data Size for Sending], the data is divided when sent. If the size of the data being sent exceeds the value set for [Maximum Data Size for Sending] when the Divide Data setting is set to 'Off', the data is divided by pages and sent as multiple e-mails. (See "Maximum Data Size for Send.")
Make sure to check the specifications of the destination's e-mail software before setting this mode. If you set conditions that the recipient's machine does not support, a transmission error may occur.
To add another destination, press [Next Destination] → repeat steps 3 and 4.
5.
Press [OK].
