      0SU0-026
      Printing from USB Memory (USB Print)
      You can print files stored in a USB memory device by connecting it directly to the machine. Using this function, you can print without using a computer. Make sure that this function is enabled before operation (Restricting the USB Print Function).
      Available File Formats
      You can print the following types of files.
      JPEG (DCF/Exif 2.21 or earlier/JFIF)
      TIFF (JPEG/MH/MR/MMR compression)
      PDF (1.7)
      For JPEG and TIFF files, maximum printable data size per file*1 is 50 MB*2.
      *1 For multi-page TIFF files, maximum data size is per page.
      *2 Maximum data size is 20 MB when Secure Print is enabled.
      For PDF files, maximum printable data size per file is 2 GB.
      Note that even some files smaller than the size described above may not be printed correctly.
      Available USB Memory Devices
      You can use USB memory devices with the following format styles.
      FAT16 (memory capacity: up to 2 GB)
      FAT32 (memory capacity: up to 32 GB)
      Do not use non-standard USB memory devices. You may not be able to print the files properly with some USB memory devices.
      Do not connect anything other than a USB memory device. USB memory devices cannot be connected via a USB hub or an extension cable.
      Do not use USB memory devices with special functions such as built-in security functions.
      If a folder in a USB memory device has many files, scanning files to print will take more time. Use your computer to delete unnecessary files on your USB memory device or move them to a different folder.
      1
      Connect a USB memory device to the USB memory port.
      IMPORTANT:
      The USB port on the right side of the machine toward the rear is not available.
      Do not disconnect, jostle, or turn OFF the machine or USB memory device while the data is being transferred.
      2
      Press  (DIRECT PRINT).
      3
      Use / to select <Select File and Print>, and press .
      NOTE:
      Index Print
      You can print thumbnails of the image files (JPEG only) stored in a USB memory device. To print the images in thumbnails, select <Index Print> on the screen, and proceed to the next step.
      To change the file sort order
      You can change the sort order of the files in a USB memory device.
      NOTE:
      You can specify a sort setting such as <Name (Ascending)> or <Date/Time (Ascending)> as the default setting for the file sort order. File Sort Default Settings
      4
      Select the file to print, and press .
      You can select multiple files.
      To clear a selection, select the file you have selected (marked as ), and press .
      To display the contents of a folder, select a folder, and press  or . To return to the folder in the upper level, press  (Back) or .
      NOTE:
      Folders and files lower than the third directory are not displayed.
      When you move to another folder, the previous file selections will be cleared.
      You cannot select JPEG/TIFF documents and PDF documents at the same time.
      To select all files
      Select <Select All>, and press . All the displayed files are selected.
      To clear all selections, select <Clear All>, and press .
      5
      Select <Apply>, and press .
      6
      Specify the print settings as necessary.
      To specify the print settings for all file formats
      Use / to select the settings, press and specify each setting.
      To specify the print settings only for JPEG/TIFF files
      Use / to select <Set JPEG/TIFF Details>    specify the setting   <Apply> .
      To specify the print settings only for PDF files
      Use /  to select <Set PDF Details>    specify the setting    <Apply> .
      7
      Press .
      Printing starts.
      To cancel print jobs, select <Cancel>    <Yes>  .
      8
      Disconnect the USB memory device from the USB memory port.
      1
      Press .
      2
      Press  (Status Monitor).
      3
      Use / to select <Device Status>, and press .
      4
      Select <Remove Memory Media>, and press .
      Wait until the <Memory media can be safely removed.> message is displayed.
      5
      Disconnect the USB memory device.
      TIPS
      If you always want to print with the same settings: Changing Default USB Print Settings
