      0SU0-06Y
      Paper
      Supported Paper Sizes
      Paper sizes that can be loaded in the paper drawer, the multi-purpose tray, and optional paper drawers are listed below.
      A4 (8 1/4" x 11 3/4" [210 x 297 mm])*1 *2 *3
      B5 (7 1/8" x 10 1/8" [182 x 257 mm])*2
      A5 (5 7/8" x 8 1/4" [148 x 210 mm])*2
      Legal (8 1/2" x 14" [215.9 x 355.6 mm])*1 *2 *3
      Letter (8 1/2" x 11" [215.9 x 279.4 mm])*1 *2 *3
      Statement (5 1/2" x 8 1/2" [139.7 x 215.9 mm])*2
      Executive (7 1/4" x 10 1/2" [184 x 266.7 mm])*2
      Officio (8 1/2" x 12 1/2" [215.9 x 317.5 mm])*1 *2 *3
      B-officio (8 1/2" x 14" [215.9 x 355 mm])*1 *2 *3
      M-officio (8 1/2" x 13 1/2" [215.9 x 341 mm])*1 *2 *3
      Government - Letter (8" x 10 1/2" [203.2 x 266.7 mm])*1 *2 *3
      Government - Legal (8" x 13" [203.2 x 330.2 mm])*1 *2 *3
      Australian-foolscap (8 1/8" x 13 1/4" [206 x 337 mm])*2
      Foolscap (8 1/2" x 13" [215.9 x 330.2 mm])*1 *2 *3
      Envelope COM10 (4 1/8" x 9 1/2" [104.7 x 241.3 mm])*2
      Envelope Monarch (3 7/8" x 7 1/2" [98.4 x 190.5 mm])*2
      Envelope C5 (6 3/8" x 9" [162 x 229 mm])*2
      Envelope DL (4 3/8" x 8 5/8" [110 x 220 mm])*2
      Custom Paper Size*4
      *1 Automatic 2-sided printing is available without replacing paper.
      *2 You can load in the multi-purpose tray.
      *3 You can load in the paper drawer.
      *4 Custom paper size of 3" to 8 1/2" (76 to 216 mm) in width and 5" to 14" (127 to 356 mm) in length can be loaded in the multi-purpose tray.
      The default paper size of the machine is set to Letter. Change the paper size setting when using a different size of paper.
      Paper Type and Paper Source Capacity
      Chlorine-free paper can be used with this machine.
      Paper Type
      Paper Capacity for Paper Drawer
      Paper Capacity for Multi-Purpose Tray
      Plain paper*1
      17 lb bond to 21 lb bond (64 to 80 g/m²)
      500 Sheets
      100 Sheets
      22 lb bond to 24 lb bond (81 to 90 g/m²)
      480 Sheets
      90 Sheets
      Heavy paper
      25 lb bond to 28 lb bond (91 to 105 g/m²)
      80 Sheets
      29 lb bond to 34 lb bond (106 to 128 g/m²)
      50 Sheets
      Recycled paper*1
      500 Sheets
      100 Sheets
      480 Sheets
      90 Sheets
      Color paper*1
      500 Sheets
      100 Sheets
      480 Sheets
      90 Sheets
      Thin Paper
      16 lb bond (60 to 63 g/m²)
      110 Sheets
      Transparency*2
      10 Sheets
      Label
      40 Sheets
      Envelope
      10 Sheets
      *2 Use laser printer transparencies.
      Paper Type and Setting for the Machine
      Printable Area
      The shaded areas in the image below indicate the printable area of the document.
