      0SU0-01X
      Printing with Toner Save Setting
      You can set the printer driver to print documents using less toner.
      When the toner save setting is enabled, fine lines and portions with lighter print density may become blurred.
      [Quality] tab Select the document type in [Objective] Click [Advanced Settings] Select [Toner Save] in the [Advanced Settings] screen Select [On] from the drop-down list [OK] [OK]
      Select the document type for which you want to enable the toner save setting.
      [Advanced Settings]
      A screen with settings is displayed. Click [Toner Save] and select [On] from the drop-down list on the bottom of the screen.
      NOTE:
      In the [Advanced Settings] screen, you can specify various print settings other than toner save settings. For more information, click [Help] on the printer driver screen.
