      0SU0-01C
      Enlarging or Reducing
      You can make enlarged or reduced printouts by using a preset print ratio, such as Statement to Letter, or a custom print ratio that you set in increments of 1%.
      Setting Print Ratio by Specifying the Original Document and Paper Size (Preset Ratio)
      The print ratio is automatically set based on the document and paper size you have specified.
      [Basic Settings] tab Select the document size in [Page Size] Select the paper size in [Output Size] [OK]
      Specifying Print Ratio in Increments of 1%
      [Basic Settings] tab Select the [Manual Scaling] check box Enter the print ratio in [Scaling] [OK]
      Depending on the selected paper size, you may not be able to set the optimum enlarging/reducing ratio. For example, there may be large blank spaces on your printout, or portions of the document that are missing.
      The enlarging/reducing settings on some applications have priority over those on the printer driver.
