      0SU0-01S
      Printing Watermarks
      You can print watermarks such as "COPY" or "CONFIDENTIAL" over the document. You can create new watermarks or use pre-registered watermarks.
      [Page Setup] tab Select the [Watermark] check box  Select a watermark from [Watermark Name] [OK]
      [Watermark]/[Watermark Name]
      Select the [Watermark] check box to display the list of the watermarks in the [Watermark Name] drop-down list. Select a watermark from the menu.
      [Edit Watermark]
      Displays the screen to create or edit watermarks.
