      0SU0-027
      Changing Default USB Print Settings
      The default settings are the settings that are displayed whenever you turn ON the machine, or when you press . If you change these default settings to match the operations that you perform frequently, you can eliminate the need to specify the same settings every time you make prints.
        <Memory Media Print Settings>    <Change Default Settings>    Select the setting    Change the default value of the selected item  <Apply>
      Settings
      Select the item you want to set, and change the default value.
