      0SU0-01K
      Printing Booklet
      You can print two pages of a document on each side of paper and then fold your printed pages in half to make a booklet. The printer driver controls the print order in such a way that the page numbers are correctly arranged.
      Booklet printing may not be available with some sizes and types of paper. The paper that is available for 2-sided printing is also available for booklet printing. See Paper.
      [Basic Settings] tab Select [Booklet Printing] in [1-sided/2-sided/Booklet Printing] Click [Booklet] to specify detailed settings as necessary [OK]  [OK]
      Select [Booklet Printing].
      NOTE:
      For [1-sided Printing] and [2-sided Printing], see Switching 1-Sided and 2-Sided Printing.
      [Booklet]
      The screen below is displayed.
      [Booklet Printing Method]
      [All Pages at Once]: Prints all of the pages at once as a single bundle so that you can make a booklet just by folding the printed pages in half.
      [Divide into Sets]: Prints as multiple bundles divided by the number of the pages specified on [Sheets per Set]. Bind each bundle, and then combine them as one booklet. Select this option when the document has so many pages that you cannot bind them all into a single booklet.
      [Specify Booklet Gutter]
      If you are using a stapler or other binding tools, specify the margin width for binding your booklet. Select the [Specify Booklet Gutter] check box and specify the margin width in [Booklet Gutter].
