About the menu options in the following chart
Default settings are highlighted in bold.
The settings marked with "*A" cannot be imported or exported via the Remote UI.
For values with "*1" mark, the default value varies depending on the country where you are using the machine.
Settings
Descriptions
Dept. ID Mngt. On/Off
Specify whether to use Dept. ID Management.
Settings
Descriptions
Use SSL
Set whether to use SSL encryption whenever the machine exchanges data with a Remote UI.
IPv4 Address Filter
It rejects or allows transmissions with specific IP addresses on the IPv4 network.
IPv6 Address Filter
It rejects or allows transmissions with specific IP addresses on the IPv6 network.
MAC Address Filter
It rejects or allows transmissions with specific MAC addresses on the network.
Settings
Descriptions
Fax Settings
Set the fax settings.
Memory Lock Settings
Specifies whether to save received documents in memory without printing them out.
Memory Lock PIN
Specifies a PIN number (seven digits) necessary for changing Memory Lock Settings.
Print Report
Specifies whether to print Receive Results information.
Memory Lock Time: Not Set
Specifies whether to receive documents only within a specified time.
Settings
Descriptions
Print Images
Set whether to print forwarded items.
Store Images in Memory
Set whether to store forwarded items in image memory.
Settings
Descriptions
Address Book PIN
Set a PIN to protect the address book.
When you specify a PIN, you need to enter the registered PIN before registering destinations. |
Restrict New Destinations
Specifies whether to permit specifying of destinations using the numeric keys.
Allow Fax Driver TX
You can specify permission to send faxes from computers using the fax driver.
Restrict History TX
Specifies whether to permit specifying of destinations from the history.
Fax No. Confirmation Re-Entry
Specifies whether to display a screen for re-entering a fax number when entering the fax number using the numeric keys.
Restrict Sequential Broadcast
Specifies whether to permit sending of a fax to multiple recipients.
Also, you can specify a confirmation notice when sending a fax to multiple recipients.
Settings
Descriptions
Network
It sets the Page Description Language that will be selected when a PnP device on the network is connected.
USB
It sets the Page Description Language that will be selected when a PnP device is connected using USB.
System Administrator Settings
Device Information Settings
Dept. ID Management On/Off
Network Settings
Security Settings
Communication Management Settings
Forwarding Settings
Store/Print When Forwarding
Remote UI On/Off
Restrict TX Function
Display Job History On/Off
USB Device On/Off
Memory Media Storage On/Off
USB Direct Print On/Off
Secure Print Settings
Select PDL (Plug-n-Play)
All of the above
