Initializing the Key and Certificate
Resets the key and certificate or CA certificate to the default values.
Key and certificate: none (all have been deleted)
CA certificate: 1 (the default preinstalled CA certificate)
About function settings
When the key and certificate are initialized, IEEE802.1X TLS certificate and SSL setting are set to "Off."
1
Press [
] (Menu).
2
Select <System Settings> using [
] or [
] and press [OK].
When the system manager ID and system manager PIN are specified
Use the numeric keys to enter the ID and number, and then press [
] (Log In/Out).
3
Select <Initialize Key and Certificate> using [
] and [
] and press [OK].
4
Select <Yes> using [
] and press [OK].
Initializing is performed.
5
Press [
] (Menu) to close the menu screen.
