Initializing the System Management Settings
07K4-041
Restore the following settings to the default settings separately or together.
System Manager Information Settings
Device Information Settings
Dept. ID Management On/Off
Network Settings
Communication Management Settings
Forwarding Settings
Store/Print When Fowarding
Select Country/Region
Remote UI On/Off
Restrict TX Function
Display Job History
USB Device On/Off
Memory Media Storage On/Off
USB Direct Print On/Off
Select PDL (Plug-n-Play)
All settings mentioned above
1
Press [
] (Menu).
2
Select <System Settings> using [
] or [
] and press [OK].
When the system manager ID and system manager PIN are specified
Use the numeric keys to enter the ID and number, and then press [
] (Log In/Out).
3
Select <Initialize System Settings> using [
] or [
] and press [OK].
4
Select the item using [
] or [
] and press [OK].
5
Select <Yes> using [
] and press [OK].
Initializing is performed.
6
Press [
] (Menu) to close the menu screen.
