Confirming the Entered Fax Number
07K4-0LC
Specify whether to require confirmation before sending a fax. When this option is enabled, you are prompted to enter the fax number again before sending a fax.
The fax number confirmation screen
The screen appears only when specifying a destination using the numeric keys.
1
Press [
] (Menu).
2
Select <System Settings> using [
] or [
] and press [OK].
When the system manager ID and system manager PIN are specified
Use the numeric keys to enter the ID and number, and then press [
] (Log In/Out).
3
Select <Restrict TX Function> using [
] or [
] and press [OK].
4
Select <Fax No. Confirmation Re-Entry> using [
] or [
] and press [OK].
5
Select <Off> or <On> using [
] or [
] and press [OK].
<Off>
Do not display the screen.
<On>
Display the screen.
6
Press [
] (Menu) to close the menu screen.
