Setting the IPv4 address
Setting the IPv6 address
(1)
Select the [Use Filter] check box.
(2)
Select the [Reject] or [Allow] check box.
[Reject]
Allow accessing only from computers of which addresses specified in [Exception Addresses].
[Allow]
Reject accessing from computers of which addresses specified in [Exception Addresses].
(1)
Enter the IP address to be excepted.
(2)
Click [Add].
Input Method
Single Address
Enter the IP address by adding periods between the numbers.
For example, "192.168.0.10"
Multiple Addresses
Enter multiple addresses sequentially by adding hyphens between the addresses.
This specifies the range of IP Addresses to be excepted. For example, "192.168.0.10-192.168.0.20"
Prefix Address
Add a slash after [Prefix Address] and put [Prefix Length] after the slash to specify an IPv4 address prefix.
This specifies the prefix to be excepted. For example, "192.168.0.10/24"
(1)
(2)
Click [Add].
Input Method
Single Address
Enter the IP address by adding colons between the groups.
For example, "fe80::10"
Multiple Addresses
This specifies the range of IP Addresses to be excepted. For example, "fe80::10-fe80::20"
Prefix Address
Add a slash after [Prefix Address] and put [Prefix Length] after the slash to specify an IPv6 address prefix.
This specifies the prefix to be excepted. For example, "fe80::10/64"
To delete registered IP addresses
When the setup is complete
Restart the machine to take effect the settings.
] (Menu).
] or [
] and press [OK].
] (Log In/Out).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
<Off>
IP Address filter is not available.
<On>
IP Address filter is available.
] (Menu) to close the menu screen.
